2000 S430 AirMatic Problem - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-27-2007, 12:45 PM Thread Starter
Adam00S430's Avatar
Date registered: Feb 2007
I am having problem with my passenger side Airmatic pump making load noise almost all the time. My MB dealer told me to ride it until it fails then take it for replacement and repair for $900 or more.
Is there any way this can be fixed now or all I can do is wait till it fails and pay the prices.
Adam00S430 is offline
post #2 of 11 (permalink) Old 02-27-2007, 01:11 PM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2010 S550
Quoted: 243 Post(s)
If you are certain it is the airmatic pump, replace the pump (and pay the price) before it fails!! You will at minimum avoid having to have your car towed; you may avoid a breakdown in traffic; and you will avoid a complete failure situation that damages your struts and perhaps your wheel wells, costing you $6K or so to fix.
And you might look to a better tech to fix it. I can't believe a knowledgable dealer could advise you to drive it to failure.
While you're at it, ask the tech to check the tops of the front strut mounts (as well as the struts themselves) for leaks, and also to check the airmatic relay.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #3 of 11 (permalink) Old 02-28-2007, 01:08 AM
Mike Damiani's Avatar
Date registered: Jul 2006
Fix it before it blows. My wife was almost killed when the airmatic system deflated on the highway. The vehicle looked like a low rider and she could not steer because the tires were hitting the fender wheel openings. AAA got the car home and I replaced the Airmatic unit in only a few hours, this includes diagnosing and repair time. The "new and improved" WABCO ( original equipment ) unit wholesales for less than $300.00.
Mike Damiani is offline
post #4 of 11 (permalink) Old 02-28-2007, 12:39 PM Thread Starter
Adam00S430's Avatar
Thanks for the input. do you have more informaiton about WABCO? I am not familiar with that term.
post #5 of 11 (permalink) Old 02-28-2007, 02:30 PM
Starglider's Avatar
Date registered: Jan 2007
Vehicle: W220, S430 LWB, 2000, 147.000 km
Exclamation
Mike, please elaborate on the "New and Improved" WABCO. It's really something that I guess nobody can even guess wtf that means
I can only try guessing It's O-Rings of the top struts that supposed to be improved
Starglider is offline
post #6 of 11 (permalink) Old 02-28-2007, 11:19 PM
WABCO is the company that makes the original equipment "Mercedes Benz" Airmatic compressor. The compressor unit includes a dryer and a deflation valve.
The link to Wabco is attached.
- WABCO
The Mercedes dealers have told me that there were many problems with the OEM pumps and the replacement pumps are "new and improved" models. The new one looks just like the old one to me, but the car is fixed, my wife thinks that I am a magician.
post #7 of 11 (permalink) Old 03-20-2007, 08:02 PM
Premium Member
Date registered: Oct 2006
Vehicle: 2009 S 550
Premium Member
Send a message via Skype™ to simontamas72
my pump made the noise one day and broke down right the next day, so better not to wait. i found my pump for $ 360 online and replaced it myself. it's not that complecated. since than no problems!!!
simontamas72 is offline
post #8 of 11 (permalink) Old 03-21-2007, 03:01 AM
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
- WABCO
the new ones are just the same as the old ones, I only difference is a higher Q number. the newer models have the same shit compressor. well not sure if its a shit compressor or the fact that the way the compressor is designed to operate. I believe they fail because they are controling the ride height on a big vehicle and the compressor is so small.
Streetglower is offline
post #9 of 11 (permalink) Old 03-21-2007, 09:13 AM
fkong777's Avatar
Date registered: Nov 2004
Vehicle: 02 S430 - 00 ML55 - 91 NSX
Send a message via Yahoo to fkong777
I read about this before. Peeps from the other forum think it can be just a relay getting stuck... Look for the relay in the fuse block and switch it with another relay that is the same part number and see if the pump will stop.
Relay is cheap. $15-$20 or so.
Do a search in here and the other place for " Pump relay "
fkong777 is offline
post #10 of 11 (permalink) Old 09-05-2008, 05:38 AM
Date registered: Sep 2007
the price?
MyStur is offline
    Airmatic/BAS on 2000 S430 Guest (MBNZ) W220 S-Class 12 05-14-2010 10:20 AM
    airmatic suspension for 2000 s500 NINO_DC W220 S-Class 4 06-21-2009 05:56 AM
    Thinking about purchasing a USED 2000 S430, what options should I look for, any problems w/ 2000?... Guest (MBNZ) W220 S-Class 10 04-18-2008 10:14 AM
    2000 S430 Power Seat Problem! HELP!!! sho1 W220 S-Class 0 11-21-2006 02:01 PM
    S430 Airmatic Setting Preferences gdtobme W220 S-Class 0 10-03-2004 10:28 PM
