Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 01-31-2007, 01:25 PM   #1 (permalink)
Vehicle: 2001 MERCEDES S430
Ive Had It!!!!
Can Anyone Help Me With This Sitution, I Had My Airmatic Message Come Up Even Though Everything Was Working A Member Told Me That I Can Un Due One Of My Battery Terminal So It Resets The Computer So When I Plugged The Terminal Back, Every Other Sign Came Up Esp.brake Assist, Abs, Airmatic. I Dont Want To Get Hosed At The Dealership Can Anyone Give Me Some Tips On What To Do.
Thanks
TOSMAN is offline   Reply With Quote
Old 01-31-2007, 02:03 PM   #2 (permalink)
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
I assume you pushed the Reset button to turn them off? Did they go off/stay off? I always thought that "remove battery cable" thing was a bad idea. Your dealer won't "hose" you to reset those "Malfunctions." They might even do it for free!
Don't believe everything you think
http://www.kcmbca.org/
Kansas City Mercedes-Benz car club
Jayhawk is online now   Reply With Quote
Old 01-31-2007, 02:04 PM   #3 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic
Airmatic is complex, and complete failure can result in expensive damage. Best advice I can offer is have your dealer check it out.
2005 S500 4-Matic
with Gateway 500 iPod integration
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 01-31-2007, 02:09 PM   #4 (permalink)
Thanks for the reply I think thats my only option,I have already booked an appointment ill let you guys know
Old 01-31-2007, 02:19 PM   #5 (permalink)
Date registered: Nov 2004
Vehicle: My Benz: 04 S430
Thanks
Did you disconnect the main battery in the trunk? or did you disconnect the Aux power under the hood?
There is no grave danger from disconnecting the battery otherwise we'd all be screwed if a battery failed and they all do sooner than later. But the Aux power unit is a different story.
Either way, Just a simple Clearing of all faults makes it all go away.they might not even charge you as it only takes a second.
BTW> PLEEEZE tell me you had the ignition off when you unplugged the battery and plugged it back in right?
My04230k is offline   Reply With Quote
Old 01-31-2007, 02:34 PM   #6 (permalink)
Yes I dissconnected from the trunk and yes my ignition was off, I just dont understand why all the messages came on after I did that, im starting to think something is wrong with my computer if reacts to power outage like that
Old 01-31-2007, 03:10 PM   #7 (permalink)
Date registered: Mar 2006
Vehicle: 2000 S 500 2002 E320 1991 300E
It is normal to see ESP/ABS message after disconnecting and connecting the cable, to reset it just turn the steering wheel lock to lock.
JOHNNY7623 is offline   Reply With Quote
Old 01-31-2007, 03:13 PM   #8 (permalink)
What do you mean by lock to lock?
Old 01-31-2007, 03:19 PM   #9 (permalink)
Start engine turn the steering wheel all the way to left and then all the way to the right, turn ignition off and start again.
Old 01-31-2007, 03:46 PM   #10 (permalink)
Wow It worked, now the only message that i have on the screen is the airmatic thanks alot for the tip ive gotto ask how did you know about that?
To those who dont Know ,Ive purchased another car and its an MB alroumi W163 M-Class 14 06-28-2006 09:15 PM
Mo$t expen$ive $ill$ in the world. ThrillKill W208 CLK Class 13 10-04-2005 09:43 PM
Ive Got Wood!!! Mercedes Boy W163 M-Class 6 08-08-2005 12:43 PM
IVE PLACED AN ORDER FOR 2006 ML500! alroumi W163 M-Class 0 12-15-2004 05:21 AM
ive seen the future, and its LED zaystev W126 S,SE,SEC,SEL,SD,SDL Class 7 02-04-2004 12:14 PM
