Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 02-23-2006, 07:21 PM   #1 (permalink)
BBALLER's Avatar
Date registered: Feb 2006
Vehicle: 2003 s500 4matic
03 w220
Do the 03 models have the same airmatic and other problems of the 00-02 models?Or have they been completely ironed out?
BBALLER is offline   Reply With Quote
Old 02-26-2006, 02:49 PM   #2 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic
RE: 03 w220
The short answer is no, but please read on.
Airmatic problems can occur in any model year using it. Any pneumatic system can develop leaks. My '00 developed cracks in the upper strut mounts - I replaced them (about $550) - and they were replaced with mounts of a different design. Had they failed, my car would have gone completely down - but I caught the problem before it could.
I also replaced the airmatic relay (inexpensive and simple) - the relay can stick. If it sticks off, your car will gradually lose ride height. If it goes all the way down while you're driving, it could cause damage to the wheel wells and fenders (as you steer). That's expensive If it sticks on, you may burn out the airmatic pump - that's expensive. If you encounter those problems, get it in for service!
I don't know what other redesigns have been done from the earlier years to the later ones, but the redesigned strut mounts show that effforts have been made to improve the system.
The system, like any other, is subject to wear - especially seals throughout. The higher the mileage, and the harder the car is driven, the sooner parts will fail. If you buy a later model car with lower mileage, you'll probabl be able to drive further before the inevitable occurs - unless you buy one where it has already occurred, and has been fixed properly.
I wouldn't let airmatic scare you. Two of my wife's Lincoln Town Cars have had their rear ride leveling springs (air shocks) replaced - $3K each time. It happens.
The long answer: Buy an extended warranty, or budget for it and enjoy your ride! There is nothing like a Benz, and airmatic increases the pleasure of the driving experience.
2005 S500 4-Matic
with Gateway 500 iPod integration
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 02-26-2006, 03:28 PM   #3 (permalink)
BBALLER's Avatar
RE: 03 w220
as usual great info, thanks.
