Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 02-22-2006, 12:29 PM   #1 (permalink)
BBALLER's Avatar
Date registered: Feb 2006
Vehicle: 2003 s500 4matic
airmatic suspension
What are the first signs that the airmatic suspension is going out? When purchasing used how can you test the suspension to see if there is a problem?
BBALLER is offline   Reply With Quote
Old 02-22-2006, 11:22 PM   #2 (permalink)
Frank_S500's Avatar
Date registered: Nov 2004
Vehicle: MB CL 500
Send a message via ICQ to Frank_S500
RE: airmatic suspension
Spray soap water on the connectors.
Check airmatic relay (disassemble).
Cheers, Frank
Frank_S500 is offline   Reply With Quote
Old 02-23-2006, 05:13 AM   #3 (permalink)
Date registered: Nov 2005
Where exactly is the relay located?
Johan
2000 S500 SPORT
DRTYLNDY is offline   Reply With Quote
Old 02-23-2006, 06:51 AM   #4 (permalink)
donniebhoy's Avatar
Date registered: Jan 2006
observe the level overnight. if one or two levels dropped- it's a leak on the strut. the relay goes bad but it's the cheapest of all the airmatic suspension parts- buy a new one. if the pump is noisy or still actuating after the level is reached then probably a a leak somewhere or could be the pump itself needs replacement. on the right fuse and relay box on the engine compartment you will find the relay. it is labeled "O". you can find the label when you remove the relays.
wait, it's not only the suspension you need to care about. consider the ICM, TV tuner and electrical leaks that was caused mostly by the OCP, telephone handset, CD changer, ESA or worse the EIS.
goodluck.[:D]
donniebhoy is offline   Reply With Quote
Old 02-23-2006, 11:05 AM   #5 (permalink)
Frank_S500's Avatar
Vehicle: MB CL 500
Right fusebox position O.
right black relay.
