Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 02-19-2006, 05:46 PM   #1 (permalink)
Date registered: Feb 2006
Vehicle: 2001 M5 2004 X5 2000 S430 2007 SL550
Enigma! - Correct Oil for 2000 S430
I would greatly appreciate it if someone could tell me what the correct oil is to use in a 2000 S430. The lame owners manual is of no use. My local lube shop insists that I use non-synth castrol 10w-30 but I was under the impression that synthetic was called for. No one seems to know for sure and its extremely frustrating.
I just want to know what brand/type/weight Mercedes officially recommends for my car. In case it helps, I live in a climate that gets down to 30 degrees in winter and up to 110 degrees in summer. Someone, somewhere on this earth has to know!
JapTrapLex is offline   Reply With Quote
Old 02-19-2006, 06:46 PM   #2 (permalink)
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
RE: Enigma! - Correct Oil for 2000 S430
Our 2002 ML320 calls for Mobile 1 (forgot which grade) synthetic oil. Other brands are accpetable too.
Your local lube shop guy is a nut. You should be using synthetic.
Our friend had an early 2000 S430, and he uses Mobile 1 synthetic oil. I hope that helps a little.
asianml is offline   Reply With Quote
Old 02-19-2006, 07:34 PM   #3 (permalink)
Chucky300's Avatar
Date registered: Oct 2002
Vehicle: 2007 S550 Sport
Send a message via MSN to Chucky300 Send a message via Yahoo to Chucky300
Hmm. Yes - My dealer (MB Manhattan) reccomends MOBILE 1 Synthetic, but i dont know the grade either. I suggest calling ur local dealer, or to play it safe, put in the best.
brad
Chucky300 is offline   Reply With Quote
Old 02-19-2006, 09:56 PM   #4 (permalink)
lear31a driver's Avatar
Date registered: Jan 2006
Vehicle: 07 E63 AMG Black on Black
The answer is Mobile Synthetic only, never a traditional oil. The lubrication qualities of synthetic are far superior to the petro based variety. Oil type should be 0-40 weight, mobile 1 is offered in 0-30 and 0-40.
lear31a driver is offline   Reply With Quote
Old 02-20-2006, 12:11 AM   #5 (permalink)
According to my Service Booklet MB recommends only synthetic motor oil. It lists Mobil 1, Valvoline, Quaker State, Pennzoil and Castrol among others.
For Mobil 1 it suggests 0W-40 or 15W-40 but I have only used the 0W-40 in mine.
For sure the synthetic grades are the only ones to use.
normrkey is offline   Reply With Quote
Old 02-20-2006, 07:25 AM   #6 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic
My owner's manual refers to a separate booklet - the Factory Approved Service Products Pamphlet - or says to refer to the dealer. As normrkey indicates, my pamphlet definitely recommends synthetic oils and lists types and viscosities for different brands.
I would not rely on what your local oil change quick-stop tells you. This is a time to trust your dealer and the Mercedes-published materials.
2005 S500 4-Matic
with Gateway 500 iPod integration
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 02-20-2006, 11:21 AM   #7 (permalink)
Frank_S500's Avatar
Date registered: Nov 2004
Vehicle: MB CL 500
Send a message via ICQ to Frank_S500
Lookout for :
Mercedes Blatt 229.1 (regular)
Mercedes Blatt 229.3 (regular)
Mercedes Blatt 229.5 (syntetic)
Frank_S500 is offline   Reply With Quote
