Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 02-13-2006, 12:13 PM   #1 (permalink)
Date registered: Feb 2006
Send a message via MSN to smith_t240
Need help identifying 2001 S500 rims
Hi all, looking for some help here, please! I have acquired these rims from a friend and am currently trying to sell them.
What is the bolt pattern on a Mercedes 2001 S500?
5 x 112?
Wheel offset: ET44
Now I have not found Mercedes cast into the back of the rim anywhere, so I assume that these are not authentic Mercedes rims. However, I have found "Fomb" cast into the back. I see that Fomb casts rims for Mille Miglia, and the Bello rims looks very similar to what I have here (see pic). The center caps are Mercedes parts.
Also stamped into the back is 8Jx17H2 - so 17" diameter by 8" width.
These rims are currently equipped with Michelin Pilot Alpine 225/55R17 97V tires (snow tires). They are also rotational.
All four of the rims are in good shape (2 never used), two tires worn, other two tires brand new. Any suggestions on what these are worth would be great!
So again, what is the wheel bolt pattern?
Does anyone know what model these rims are - Mercedes, Mille Miglia, or other?
Approx. cost of these four rims/tires?
Thanks a lot!
Smith T
smith_t240 is offline   Reply With Quote
Old 02-15-2006, 08:51 PM   #2 (permalink)
RE: Need help identifying 2001 S500 rims
Come on guys, at least tell me the wheel bolt pattern for this car!
Old 02-16-2006, 03:32 AM   #3 (permalink)
Chucky300's Avatar
Date registered: Oct 2002
Vehicle: 2007 S550 Sport
Send a message via MSN to Chucky300 Send a message via Yahoo to Chucky300
Those wheels are Mille Miglia BELLO.......... I know that because I have them on my car right now as part of my winter tire/wheel package, purchased from Tire Rack.
Chucky300 is offline   Reply With Quote
Old 02-17-2006, 06:12 PM   #4 (permalink)
Well I can not find the Mille Miglia Bello rims in 17" so that is kind of odd, but I am assuming the bolt pattern is 5 x 112?
Old 02-17-2006, 06:55 PM   #5 (permalink)
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124
Send a message via ICQ to benzboyz Send a message via AIM to benzboyz Send a message via MSN to benzboyz Send a message via Yahoo to benzboyz
HI! I had checked the epc and the bolts should be the same with the original wheel bolts
P/N 000 990 09 70 you can try to remove one bolt from your original wheels and check for the bolt protrusion if the same length.
benzboyz is offline   Reply With Quote
