the heated/vent seats would not stay on when the buttons are pressed! Does anyone know if the heated/vent seats on my 2000 S500 can be reset? Or the problem is more complicated? Only the driver side seat is having the problem. Please advise.
I have the same problem with the A/C seats. Also the Pulse button.
The manual says the AC and heated seats (as well as pulse) will shut off if your battery is weak. You might want to check your battery. If you have weak current, the light on either of the buttons is supposed to blink to let you know power is weak.
