» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 12-10-2004, 09:51 AM   #1 (permalink)
Date registered: Dec 2004
Battery goes dead on s500 after 3 days of non-use
My battery goes dead on s500 if not started for 3 days
essentia is offline   Reply With Quote
Old 12-10-2004, 10:46 AM   #2 (permalink)
DMI+RY's Avatar
Date registered: Apr 2004
Vehicle: W220 S500 AMG
RE: Battery goes dead on s500 after 3 days of non-use
A few things to check:
1. Go to the nearest shop or MB stealership and ask the to check the fluid levels in a batttery. Also the battery shall be "cycled", i.e. fully (slowly) disharged and charged to the full again. This cycling must be done for 3 times minimum (takes about 24-48 hours for complete operation).
2. If you get started and drive for a very short distance (time) and then leave it for a few days, then battery probably couldn't get enough charge.
Also check alternator voltage (in a shop) - inproper voltage supplied by alternator may cause problems in battery charge as well.
3. In case if nothing wrong with alternator (check in a shop), your battery might be dead, so get a new one.
Hope it helps.
<hr>Life's too short not to drive a Mercedes!
DMI+RY is offline   Reply With Quote
Old 12-11-2004, 01:36 AM   #3 (permalink)
Frank_S500's Avatar
Date registered: Nov 2004
Vehicle: MB CL 500
Send a message via ICQ to Frank_S500
And, last but not uncommon, to high power consumption in idle/shutdown state.
30 min after shuting the last door, there should be no more than 50 mA power consumption.
Sometimes caused by a "sticky" relay, or a faulty contol unit.
Rgds, Frank
Frank_S500 is offline   Reply With Quote
Old 12-20-2004, 10:56 AM   #4 (permalink)
I have a S430 and the same happened to my car. After 2-Batteries replaced, I had enough and took it to the dealer. The dealer service manager metioned to me that I don't drive the car enough. According to him there are tons of computers within the vehicle are communicating to each other. I did not believe that, so they kept my vehicle for about 10 days and discovered that certain things ( OnStar/SOS Light)were staying engaged and draining the battery. I drive it more now and have had no problems. My fingers are crossed!
Rogoal16 is offline   Reply With Quote
