Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 03-10-2004, 09:13 AM   #1 (permalink)
Date registered: Mar 2004
Vehicle: S600L-2000-w220
s600 Engine Idle Vibration
Hi,
When I am stationary e.g. traffic lights, I can feel a very noticeable vibration throughout the front of the car. I have taken my year 2000 model to a dealer who replaced two ignition coils and some of the 24 spark plugs without any noticeable difference. The dealer also checked the engine Mass AirFlow sensor.
Apart from this the car drives fine and driving other than when stationary is superb.
Please can anyone who has had this problem advise.[?]
s600owner is offline   Reply With Quote
Old 03-11-2004, 05:01 PM   #2 (permalink)
900Gold's Avatar
Date registered: Jan 2004
RE: s600 Engine Idle Vibration
Have them check the motor mounts. With the age of your Benz and the added weight of the engine with all that torque.
900Gold is offline   Reply With Quote
Old 04-21-2004, 11:29 PM   #3 (permalink)
angldrkns9's Avatar
Vehicle: 2004 Carrera 4S
Send a message via AIM to angldrkns9 Send a message via MSN to angldrkns9
s600owner - 3/10/2004 11:13 AM
Hi,
could be the fuel sensor.. had that problem on my '03 S55
JASON
2004 Porsche Carrera 4S
2003 Mercedes Benz S55 ///AMG
2000 Mercedes Benz ML55 ///AMG
angldrkns9 is offline   Reply With Quote
Old 04-22-2004, 10:13 AM   #4 (permalink)
Merc600sec's Avatar
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
Me too I have spoken to several people about it, i dosnt happen all the time though, someone sugested that it might just be a doddgy lanbada sensor, get an auto eletrinics mech to read the fault codes for you write them down and then ask on the w140 forum
Merc600sec is offline   Reply With Quote
Old 04-26-2004, 06:50 AM   #5 (permalink)
sleepwalker's Avatar
Date registered: Apr 2004
Send a message via ICQ to sleepwalker Send a message via MSN to sleepwalker Send a message via Yahoo to sleepwalker
TRY THIS:
ON THE LEFT SIDE SAM (SIGNAL ACQUISITION MODULE) OR FUSE BOX IS THE DME CONTROL UNIT.
REMOVE ALL THE PLUG CONNECTORS TO THAT CONTROL UNIT AND YOU MIGHT FIND IT SOAKED IN OIL!
THE OIL IS COMING FROM THE DEFECTIVE FUEL PRESSURE SENSOR FOR THE CSO (CYLINDER SHUTOFF VALVE) OF LEFT BANK CYLINDER (7-12).
MAKE SURE THAT THE CHECK ENGINE LIGHTS "ON" EVERYTIME YOU TURN ON THE IGNITION, THEN IT WILL GO OFF AFTER STARTING. TECHNICIANS USUALLY CHEATS BY SETTING IT TO NOT ACTIVE STATUS TO PREVENT YOU IN COMING BACK FOR COMPLAINT.
DO IT AND YOU WILL FIND OUT.
sleepwalker is offline   Reply With Quote
