Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 12-08-2003, 12:30 AM   #1 (permalink)
Date registered: Dec 2003
do w220 S55 rims fit on w140 (92-99 S class)
Hello,
Just wondering if anyone knows whether or not W220 and W140 wheels can be swapped.
Will W140 16" stockers fit on S55 (for winter)?
Will stock S55 AMG's fit on a W140?
Thanks
96 S500 Coupe. Black on black, 18" AMGs
snik is offline   Reply With Quote
Old 12-09-2003, 02:28 AM   #2 (permalink)
scorchie's Avatar
Vehicle: CLK55/G500/E55/ML55/etc.
RE: do w220 S55 rims fit on w140 (92-99 S class)
snik - 12/7/2003 12:30 AM
Hello,
Thanks
16" wheels of any type will probably not fit an S55, due to brake caliper clearance on the front.
The S55 AMG wheels should fit the W140 just fine.
-s-
1987 190E / 1987 300E x2/ 2001 CLK55 / 2001 ML55 / 2002 G500 / 2003 E55 / 2006 R350 / 2006 G450 / 2007 sumtin sumtin
scorchie is offline   Reply With Quote
Old 12-10-2003, 04:41 PM   #3 (permalink)
thanks
i put them on (AMG type I's from a 02 S55 on a 93 S500) and they fit perfectly, no rubbing either.
only thing is back wheel studs portrude out ever-so-slightly, and the front wheel studs are recessed a bit (sit inside the wheel stud hole in the wheel whereas the back ones stick out).. am I to assume i will needs studs from a S55 or is it ok to run with the existing wheel studs even though they may stick out a bit?
