Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W219 CLS Class
Old 07-20-2008, 02:05 PM   #1 (permalink)
old goat's Avatar
Date registered: Jun 2007
Uneven lowering with links, question???
Hey guys, i lowered my car with links, great product. But i noticed the rear passenger sided always sits just a little higher then the other side. The rear only has 1 sensor so i can't adjust it. WTF? Anyone have any suggestions?
Please do not write the link is faulty because all it does is readjust the factory sensor, so if thats the case the factory sensor is at fault.
old goat is offline   Reply With Quote
Old 07-28-2008, 05:06 PM   #2 (permalink)
Bigpunch8's Avatar
Date registered: Feb 2008
I have the same problem..
Bigpunch8 is offline   Reply With Quote
Old 07-31-2008, 09:48 PM   #3 (permalink)
Date registered: Jan 2007
You can get a fat assed girlfriend and sit her in on the high side when you go cruising. Problem solved.
chris betro is offline   Reply With Quote
Old 08-04-2008, 08:33 PM   #4 (permalink)
Date registered: Apr 2008
did you guys find a fix yet?
3ktt is offline   Reply With Quote
Old 08-06-2008, 09:11 PM   #5 (permalink)
old goat's Avatar
not really
Old 08-06-2008, 09:18 PM   #6 (permalink)
is it possible one of the fronts is set higher than the other? I had a problem similar to this on a truck one time and is was the result of uneven torsion bars. basically one of the front corners was higher, resulting in a lower rear corner.
lowering links and renntech module ian_black W211 E-Class 3 05-31-2008 05:40 PM
E55 Lowering Links (Front) MD/VA/DC Area Quick E55 For Sale, Trade & Wanted Items 2 05-06-2007 08:47 AM
It looks like all the links under 'Useful links 4 new members' are pointing to the same thread. HEX20 R170 SLK Class 3 01-19-2006 10:17 AM
Size of rear sway bar end links ... w/ lowering Neno23 W163 M-Class 0 10-29-2004 12:02 AM
Lowering question Quasar R170 SLK Class 3 04-09-2002 01:54 PM
