Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W219 CLS Class
Old 04-25-2008, 12:57 PM   #1 (permalink)
Date registered: Jul 2006
CLS55 Wheel Offset Question
I'm looking at putting 20" wheels on a CLS55. Considering a set with 9 inch fronts with 26 mm offset and 11 inch rears with 31 mm ofset. Will be running 255 and 305 tires. Any clearance problems? Thanks for the help.
dmdeleo is offline   Reply With Quote
Old 04-26-2008, 09:14 AM   #2 (permalink)
Date registered: Jun 2007
my 20x9 are +25 fronts and 20x11 are +28 rears. dont know it this helps any, probably not cause not only are they different wheels but the pad height is also different on each manufacture's wheels
paulfromtulsa is offline   Reply With Quote
Wheel offset and wheel spacer question for 123 wagon Alpheus The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-15-2008 04:43 PM
Wheel Offset Question......... NorCalSL R/C107 SL/SLC Class 3 11-01-2007 04:25 PM
Please help with wheel offset question, THANKS! Designo_E320 W215 CL Class 6 07-16-2007 08:53 PM
wheel offset question... krk230 R170 SLK Class 7 08-29-2004 02:21 AM
78 sl wheel offset question Jduc Vintage Mercedes-Benz 1 05-18-2004 04:43 PM
