Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W219 CLS Class
Old 03-31-2008, 12:05 PM   #1 (permalink)
yankee1's Avatar
Date registered: Mar 2008
Vehicle: 2007 CLS63 AMG
Oil Consumption
My '07 63 AMG is using (not leaking) about a quart every 1000-1200 miles--NE1 else have same issue? So much for recommended 10,000 mile oil change schedule
yankee1 is offline   Reply With Quote
Old 03-31-2008, 12:25 PM   #2 (permalink)
yankee1's Avatar
ooops--OIL CONSUMPTION
Old 04-03-2008, 03:05 AM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
every 63 that comes into our shop is always low by 2-3 quarts of oil and that is one of the complaints. i fell too that those cars burn oil but according to benz its normal in those cars for the first 500-10,000 miles
Streetglower is offline   Reply With Quote
Old 04-07-2008, 03:49 PM   #4 (permalink)
yankee1's Avatar
mine has 16K miles and still using oil--i assume that because of the larger tolerances the engines overall life increases versus engines with much small tolerances and therefore more wear
torque numbers for oil drain plug & oil filter canister? ProV1x W210 E-Class 2 12-30-2006 12:41 PM
Are these gaskets light or heavy wear? (Oil pan & oil filter) Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 9 08-24-2006 06:57 AM
HOWTO: Replacing Cam Oil Line Fittings (Oil Guides) on the 119 (5.0L) V8 inetd W140 S-Class 3 12-02-2004 09:01 AM
oil exceeds max warning....i get this everytime i get an oil change with 8.5 qrts..is that too much. concerned W208 CLK Class 2 10-21-2001 05:56 PM
