Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W219 CLS Class
Old 03-05-2008, 01:06 PM   #1 (permalink)
scoron's Avatar
Send a message via AIM to scoron
CLS55 FOG LED REPLACEMENT HELP
I am trying to swap out OEM fogs on a cls amg with LED based fogs. upon connecting and turning on it blinks for a while then shuts off. I guess failing the load test or something. Has anyone replaced this before and if so can you advice as to what ohmage reisistors I might need to augment the circuitry with so as to have it to work and the error message on cluster nto to be tripped?? PLEASE HELP!!!!!!!!!!!
scoron is offline   Reply With Quote
Clearing Error on Dash Caused By LED rear fog light? Tri-Star W203 C-Class 0 10-25-2007 06:44 AM
Mirror LED replacement? David's 2002 ML 320 W163 M-Class 4 10-05-2007 01:34 AM
Mirror LED Replacement F18lumpy W210 E-Class 3 12-22-2005 07:36 PM
LED replacement bulbs AutoSaurus W211 E-Class 2 07-07-2003 07:13 AM
LED Replacement Bulb Beng R170 SLK Class 9 09-23-2002 11:27 PM
