Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W219 CLS Class
Old 11-02-2006, 05:01 PM   #1 (permalink)
watson's Avatar
Date registered: Oct 2006
Vehicle: CLS 320 CDI
comand unlock codes-engineering mode
Hi all. It seems to be the Holy Graal indeed .... Dear friends , I post all my little knowledge about TV unlock codes with the hope that someone can help me on my car. The following codes are applicable to several type of cars and disks releases: I'm not able to specify more than this. Well , let's show down. Except with the 5+3+7 sequence and the NAV+5 one (don't touch anything if you are not sure about you are doing!!!) I had no success with all the following codes : mute+phone dwn+serv / phone down+1+3+6 / mute+3+4+6 / mute+357 / 1+3+arrow left / 1+3+9 . My car is a cls 320 oct- 2006 . All these codes didn't work , but made NO damage (on my car) . Is anything else to test ? I assume the risk to bend my fingers permanently togheter.
Please, send everything you know. Thanks a lot.
Ciao
watson is offline   Reply With Quote
Old 11-02-2006, 09:46 PM   #2 (permalink)
Kevin M.'s Avatar
Date registered: Jan 2006
Ciao Watson,
PM me your email and I will send you a PDF on the codes.
Kevin
Kevin M. is offline   Reply With Quote
Old 11-03-2006, 02:14 PM   #3 (permalink)
watson's Avatar
Hi Kevin. Done. Waiting the PDF
to give an end to this toxic nightmare....
Ciao
Old 11-04-2006, 09:32 AM   #4 (permalink)
Date registered: Nov 2006
same for me...
Ciao
Hi, I tried these codes too, but no go... (on european CLS 320CDI oct'06) Anyone has a suggestion for a working code?
Thanks,
Louis ( louismacsimon [at] telenet.be )
LouisMacSimon is offline   Reply With Quote
Old 11-04-2006, 09:41 AM   #5 (permalink)
Kevin M.'s Avatar
If they are not working on your 06 Euro Comand, then I believe MBZ updated the Comand units to ellimante the backdoor entry. They were getting smart since people knew how to modify the units. You will have to purchase a older unit to get DVD.
Lousi, can you watch DVD's while parked? just not in motion?
Old 11-04-2006, 10:39 AM   #6 (permalink)
Yes, it works when parked, not in motion.
Old 11-04-2006, 05:54 PM   #7 (permalink)
watson's Avatar
Hi Kevin. Compliments fo the European Tour report. I don't speak German, but when I saw that PDF file I said in perfect German : 'Aaahrgg!'...
I had already downloaded it some days ago. No results at all. Thanks a lot anyway. The problem is that they changed the entry codes. They didn't remove them, but simply changed them. I'm sure. It's a matter of time..... We will catch them.... If you had help in the future , please tell me.
Did you meet authentic roman Centurion 2000 years old? I hope you made a photo with them... Nice.
Ciao
Old 11-04-2006, 07:20 PM   #8 (permalink)
Kevin M.'s Avatar
Like Watson said below, they have changed the codes in the 06, it will take some time for someone to figure them out.
Ciao
Watson, glad you enjoyed the Euro Tour, will look you up next time were in Italy!
Old 11-06-2006, 07:50 PM   #9 (permalink)
watson's Avatar
Hi guys . It's me. I report some notes coming from Benznl or something like this. He seems to know the argument.
------------------------------------- he wrote ----------------------
I know that most people don't care about what we type as it usually is not what they want to read - but for those who do want to read it and are actually willing to believe it:
The euro comand (211, 219, 171) software has been updated again and one of the changes has been the HOW-TO-ENTER the developers menu on the comand so that the all-known Ebay selling method is no longer usefull (yes, mercedes does know what is going on on the web ).
When one figures (s)he can outsmart mercedes by uploading the older software version into the comand so that the developers menu becomes available again one will find oneself left with a USELESS comand [/b]as the comand will NO LONGER accept discs after the software DOWNDATE!!!
If you can find a shop with a tool to versioncode the comand for TV & DVD in motion enabling, they can still help you out (no need to swap the EURO comand out - just get it coded), but that will cost more then a 30USD ebay guide (which only works on a limitted amount of comands anyways...but that is something that Ebay sellers usually don't bother to advertise).
use this info if you want or just plain ignore it like most people do
greetingz,
------------------------------------ here he finished ---------------------------
So they changed.... they didn't remove the entry combination.....
Think about people, think about.....
For Kevin: in a few days I'll prepare something to see (and for all the friends of this forum who want to see photos of Italy)
Ciao
Old 12-18-2006, 08:36 AM   #10 (permalink)
watson's Avatar
Hi guys. At last I got the solution !!! . It was so simple. It's a little instrument to connect through the usual slot to the optical ring. In about 1 minute the job is completed and it can be disconnected. Easy. They say it's permanent. It works just fine. I think that it can be found everywhere (U.S.A., U.K., Germany....)
I don't like to spread the information everywere. I have the idea that if the key sequence had not been spreaded , may be M-Benz wouldn't change the engineering mode entry point so soon. So all the friends of the forum needing this information can write to flavio.morosi@tiscali.it. I'll reply as soon as possible.
Ciao
How to access engineering mode for command? pardillete W211 E-Class 38 11-27-2008 12:36 AM
Unlock comand codes watson Audio & Telematics Forum 0 11-02-2006 04:20 PM
COMAND - Engineering Mode? esprit W220 S-Class 1 10-09-2006 02:40 PM
Engineering mode w209 njos W209 New CLK Class 7 09-20-2006 09:18 AM
COMAND hidden 'Engineering menu' ianx, manchester R171 SLK Class 6 12-17-2004 02:02 PM
