Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W219 CLS Class
Old 09-21-2006, 03:20 AM   #1 (permalink)
Date registered: Sep 2006
W219 CD-Changer Installation
I recently got a cd-changer installed in my CLS with the help of Kevin M. (Thank you, thank you!)
I purchased the changer online, and found out that I needed to purchase an installation kit. Luckly, my local dealership had one in stock. Once I had all the parts, it took me 10 minutes to install the whole thing. No kidding. I don't even want to know how much the dealer would charge for this simple job.
Installation Kit includes all the parts you need. (B67 82 4024) - Fan, two fiber optic cables+plug, couple cable ties, bag of screws, and power cable. In my car, power cable was already pre-wired, and all I needed was the fan adapter, one optic cable+plug and two screws.
You are basically inserting another fiber-optic plug in the ring. CD changer will be attached to the "ring" using that new plug. One of the pictures below, I am holding on to two plugs. Left one is for the head unit, and the right side plug is the new plug for the changer.
From left to right, there are 1 through 4 cables. Cable 3 was originally in the hole 2. To add another plug 'A211 540 31 32' in the chain, I removed the original cable 2, and plugged that into the open hole(hole 3) in the new plug. Finally plugged the optic end of the new part(cable 2) into the hole 2 to close the chain.
Hope that somewhat makes sense. If you need details on the installation, let me know. I've taken many pictures at each step of the installation process.
Cheers!
Daniel.
DanielCLS is offline   Reply With Quote
Old 09-22-2006, 12:31 AM   #2 (permalink)
Kevin M.'s Avatar
Date registered: Jan 2006
Great job Daniel, lets see some exterior and interior shots of that beauty
Kevin M. is offline   Reply With Quote
Old 09-22-2006, 01:21 AM   #3 (permalink)
Kev,
Car is in the shop right now for service C, Nav install, and a few other things like 1st to 2nd gear rough shifting, etc. I will be applying Zaino this weekend, so I am sure I will have some pictures. I will post some of them here.
Again, thank you for all your help.
Daniel.
Old 03-01-2008, 01:12 PM   #4 (permalink)
Date registered: Feb 2007
hmmm im trying to figure out how to wire up the power wire kit.
red w/fuse = plugs into where?
pink = plugs into where?
brown = naturally to ground.
i dont see a place where the red/pink plugs into anywhere. any ideas?
jimal is offline   Reply With Quote
Old 03-01-2008, 03:12 PM   #5 (permalink)
ah nvm. figured it out.
just routed the red wire and plugged the fuse into the fuse box (driver side door side) and just tapped off the pink/brown wires off of the comand unit.
CD Changer installation vdotbob General Mercedes-Benz 13 11-15-2007 01:23 AM
CD Changer Installation help mikealdo Audio & Telematics Forum 8 01-06-2007 10:11 AM
Changer Installation XPndrgn Audio & Telematics Forum 1 07-01-2006 10:11 PM
Need some help with cd changer installation gunsmithcat W140 S-Class 4 01-11-2004 06:38 AM
need help??? on changer installation slvr430ml W203 C-Class 2 03-08-2003 08:01 AM
