Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W219 CLS Class
Old 09-20-2006, 12:40 PM   #1 (permalink)
Date registered: Aug 2006
Rockford 360.2 or CleanSweep
From what I understand you can control your audio from the stock head unit if you go with the Rockford 360.2 and if you use the clean sweep you would have to install a volume controller. What is the benefits/disadvantages between the two.
B3NZ06 is offline   Reply With Quote
Old 09-20-2006, 08:31 PM   #2 (permalink)
Markdm3's Avatar
Date registered: Nov 2002
Vehicle: -06' CLS500 Lorinser-08' MC Design Escalade-06' Land Rover-03' Suzuki Hayabusa
I went for the Rockford piece which i received today in the mail. A buddy of mine is the local rep for JL and Alpine and he even recommended I go with the 360.2. I respect his opinion alot so I stopped doing research on the clean sweep. He mainly said to go with the 360.2 mostly because it is the simplest device to take your signal from your factory system into aftermarket amps. I'll let you know how the car sounds when its done.
Markdm3 is offline   Reply With Quote
Old 09-21-2006, 06:03 AM   #3 (permalink)
Thanks, I think I will have to go that route as well. What type of amps are you looking to go with and what subs are going to push.
Can you run a 4 channel amp for the inside speaker and still control it from the head unit? I understand you can do the subs but I would like to redo the inside speakers as well. Please let me know how your 360.2 works for you!
Old 09-21-2006, 06:53 AM   #4 (permalink)
Markdm3's Avatar
What most owners do to keep it simple and sound good are replace the 4 pairs of door speakers and use a processor like the clean sweep or the 360.2 and use a 4 channel amp to power them. A second mono or two channel amp will run the subs. Most of the installers that I have spoken to bypass the small 3" speakers in the kick panel and let the factory center channel run off the radio. In any case, you will control the entire system from the radio. Tuning the 360.2 is really cool if you have a bluetooth device like a Palm or a Treo phone.
Old 09-21-2006, 08:14 AM   #5 (permalink)
That sounds great! I guess I need to start looking into Subs, speakers and amps! Any suggestions?
Old 09-21-2006, 08:07 PM   #6 (permalink)
Markdm3's Avatar
Lots of good choices. I'm debating between JL Audio, Boston Acoustic, MB Quart components with Kicker subs/amps
Old 09-22-2006, 06:55 PM   #7 (permalink)
CaliforniaMBGuy's Avatar
Date registered: Jan 2006
Vehicle: 2007 E350 Saks Fifth Edition
Send a message via AIM to CaliforniaMBGuy
JL JL JL JL JL JL JL JL JL JL did i say JL?
Sebastian Wolski
Elite Service Advisor
Mercedes Benz of Encino
CaliforniaMBGuy is offline   Reply With Quote
Old 09-22-2006, 08:19 PM   #8 (permalink)
Markdm3's Avatar
Not sure what your getting at but JL sounds like an option!
Old 09-26-2006, 08:46 AM   #9 (permalink)
Sounds like you guys like JL...Ill have to look into either two 10" or one 12".
Old 09-27-2006, 02:39 AM   #10 (permalink)
Date registered: Jun 2006
Two 10" would be my choice...if you have enough power to supply them with, the response and kick is out of this world! Like it when the dont just shake the car the whole time, but give you a kick that only last half a sec or so at a time.
Kamikazze is offline   Reply With Quote
Anyone else getting the JL Audio Cleansweep? bocobod Audio & Telematics Forum 2 06-09-2005 01:03 PM
JL Cleansweep Vacuum Audio & Telematics Forum 0 06-08-2005 06:42 AM
Alpine or Rockford Fosgate? mrfu R170 SLK Class 13 11-13-2004 01:21 AM
Has anyone tried the rockford fosgate 6 3/4 subs? Jeffrimerman R170 SLK Class 1 06-16-2003 12:23 AM
Rockford Fosgate RFX-9400 cd-mp3 car audio player.......... Tom (Vancouver) R170 SLK Class 10 08-24-2001 03:35 PM
