Not sure if you need to change any of the Active X settings in your computer to see or add your picture files, but to the best of my ability to describe the process,
1) write your text
2) Check the box at the bottom indicating "attach a file after posting"
3) You can either type the URL, or click "Browse" to find the photo from your saved pictures or documents that you want to attach to the post.
You might also try a search within the BenzWorld Support Forum down towards the bottom of the forum page. Hope this helps - - welcome to the forum and good luck!
Regards
Vehicle: Two MB S Classes: 1989 560 SEL (W126) AND 1996 S500 (W140)
RE: posting picks ?
If all else fails, you can make a gallery and post your pictures there. Then everything should work fine. You can also use the test forum to test your post out.
My cars:
BLACK 1996 S500 (W140)
BURGUNDY 1989 560 SEL (W126)
____________________________________________
