» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W219 CLS Class
Old 11-13-2005, 03:26 PM   #11 (permalink)
Date registered: Jun 2005
RE: CLS500 Transmission problems anyone?
BeeJay - Have you read the manual of your CLS? If you do you will find a superb system to stop your car rolling back, forwards and even make the hill starts real easy. If you push firmly down on the brake once stopped it automatically applies the brake and keeps it on until you touch the accelerator to go. You can tell when it is applied because the display indicated something like SBC H. If you read the manual it tells you how to apply it.
normano is offline   Reply With Quote
Old 11-14-2005, 02:34 PM   #12 (permalink)
Date registered: Nov 2005
Vehicle: CLS500
Normano-
Many thanks for your reply.
Yes, I did know about SBC Hold and I have tried to re-activate it according to the manual, but without any success.
I'm taking the car in to the dealer tomorrow and will report back to you as to why I can't get it to work.
BeeJay is offline   Reply With Quote
Old 11-16-2005, 03:59 PM   #13 (permalink)
Vehicle: CLS500
normano - malfunction - SBC Hold feature.
After investigation back at the MB dealership it's now working again, albeit requiring a lot more downward pressure on the brake pedal to activate than it did originally.
I can live with this as long as it keeps working every time and not just intermittently!
Old 12-06-2005, 05:44 PM   #14 (permalink)
I, too, have had serious transmission problems with my cls 500 and am not very happy about it. I purchased the car in May and almost immediately noticed a decided "clunk" as I slowed to a stop, especially when the car was cold. My local dealer in Louisville, KY, was very accomodating, and after failing to be able to adjust the software, replaced the transmission. They indicated other users of the 7 speed transmission had similar problems. However, the new transmission failed to stop the problem, and I have had it back several times since. In addition to the clunking upon a cold stop, I also got very rough upshifts to 2nd and 3rd. Once the dealer reprogrammed the shift computer altogether, which seemed to fix the problem, only to have it recurr. The car is now back at the dealer with instructions to fix it or keep it. I'm very disappointed that Mercedes has released a transmission without the bugs being worked out. The car is beautiful and handles well, but I had a '56 Ford that shifted better than this car does. It's my fourth Mercedes but will be my last unless this is fixed. [:(!]
mbc 1944 is offline   Reply With Quote
Old 01-19-2006, 05:10 PM   #15 (permalink)
Vehicle: CLS500
Hi mbc1944
Did you get your cls transmission problem sorted out eventually?
Mine is still slightly suspect at just 2000 miles and I'm beginning to feel that it will have to be replaced.
If there is now a modification available since the October 05 build date of my transmission, I will go for it at the first major service inspection.?!?
Old 01-19-2006, 06:47 PM   #16 (permalink)
1996_S500's Avatar
Vehicle: Two MB S Classes: 1989 560 SEL (W126) AND 1996 S500 (W140)
Send a message via ICQ to 1996_S500
wow. transmission problems on a pretty much brand new car...
My cars:
BLACK 1996 S500 (W140)
BURGUNDY 1989 560 SEL (W126)
____________________________________________
1996_S500 is offline   Reply With Quote
Old 01-19-2006, 06:49 PM   #17 (permalink)
asianml's Avatar
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
1996_s500 - 1/19/2006 8:47 PM
You haven't seen nothin. Take a look at the W164 forum. It's those darn 7-speed trannies.
asianml is offline   Reply With Quote
Old 01-20-2006, 04:49 PM   #18 (permalink)
1996_S500's Avatar
asianml - 1/19/2006 5:49 PM
jees. Does the factory warranty cover any of it?
Old 01-21-2006, 02:00 PM   #19 (permalink)
asianml's Avatar
1996_s500 - 1/20/2006 6:49 PM
I think the culprit is the software. So the dealer will replace it with the new software free of charge. But there are other reasons too.
Old 01-21-2006, 11:27 PM   #20 (permalink)
1996_S500's Avatar
asianml - 1/21/2006 1:00 PM
thats good their doing at least one thing for free.
