Thanks a lot eric242340 and J19 HWS for the help.
- When you say "voltage was any higher than 2.87 it wouldn't do a thing on mine" you reffer that cannot get succesfully calibration or that is not doing nothing in the heigth of the strut? you front rigth corner is at 2.87V and 5.5 angle?
- When you do the calibration is always with the car started? I do it with the car started but maybe I'm doing wrong....
- When you say "forget the voltages and play with the angles" you reffer that I can get values more than 3V or lower 2V and get succesfullly calibration or that I have not to move the values of the voltage and only try with differente angles? I have try all the angles in front.
In my case in the WIS says one thing and in the DAS other. In the WIS says for my car (W215-europe) front level is 2.8(+/- 1.5) front and rear level -3.3 (+/- 1.0). with this different agle admitted form romess and Star Diagnosis:
In the DAS it says for my car: 2.4 to 3.1 angle in the front and -3.3 to -2.9 in the rear. Why is this difference? One speaks about level and the other about angles but I think is the same for this, I also dont understand about the "permisible vehicle level difference between rigth and left sides" and It says for the Star Diagnosis is "0.5 in the front" and "0.3 in the rear" so I can only give angles in with this difference? or the car measures this difference in other way?... What angle I have to give to start the "try and error" method? Because I'm so confused...
After making all test avaible (rodeo, plungers, automatic level, etc.) Now I'm having another problem that I dont know if is the problem of the calibration...With the car motor running ON i'm getting values of the voltage sensors, the rear rigth is gettting 3.12V (more than 3V that says is the top...). I have change the sensor to a new one, I have be sure about the instalation, links, connections...But still in 3.12. I have to correct the voltage in the calibration or I have to get correct value before I do the calibration?
Sorry for all this to long post...but I dont get the clue to do a correct calibration....maybe with this information you can say me the next step to do.
Best regards.
