» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
BenzWorld.org is the premier Mercedes Benz Forum on the internet. Registered Users do not see the above ads.
Old 12-10-2008, 09:17 AM   #1 (permalink)
600Benz4life's Avatar
Date registered: Dec 2008
2002 CL600 key won't turn
Hi. I am new to the forum. I have a 2002 CL600. I just replaced the battery 3 weeks ago. I reset the windows and the ESP, BAS light. I went away for a week and did not start the car. I came back from vacation and I started the car. The BAS and ESP light came on. After a few minutes of driving I pulled over shut the engine off and restarted. The lights went off. I drove back home and parked the car. Two days later I go to start the car and nothing. The key opened the doors but when I stuck it in the ignition, it would not turn. After a moment of jiggling it finally turned and started the engine. I let it run for awhile then I turned it off again. I tried to restart and nothing. The key will not turn. I do not have an extra key. I checked the battery light in my key and it is functional. Has any one else experienced this problem. I live in Plano, Tx. The weather has been cool lately. The car is parked in my garage. Please advise.
600Benz4life is offline   Reply With Quote
Old 12-10-2008, 05:40 PM   #2 (permalink)
Date registered: Oct 2003
Vehicle: CL500, E430, SLK, Subaru...
Were you fairly sure your new battery was fully charged? Some are... but some are not.
Check the battery clamps are clean and tight and good. Put the thing on a trickle-charger for a full 24 hours; the key has a solenoid assembly and wants current, so it may well just be that. BAS/ABS is low low power off the battery, so it just sounds like a dead one.
Steve
London, right in the middle
03 CL500 (Black/Grey, 44k, Comand, 7GTronic, Keyless Go) 302Bhp
01 E430 (Silver/Black, 101k, Comand, Lingua, 7 seats, tow...) 275 Bhp
97 SLK (40k, Yellowstone, partner's car!) 200 Bhp
1997 Subaru Forester s/turbo (40k, black/blue, manual, sunroof) 240 Bhp
...I make that 1017 Bhp...!
LondonThing is offline   Reply With Quote
Old 12-10-2008, 07:45 PM   #3 (permalink)
Thanks for the reply. I am quite sure the battery had a good charge. I drove it 50 miles after the replacement. I drove it several times before vacation. It sat for a week and then this began. I am afraid to jump start it. I don't want to blow anything. Again, all the lights come on and the dash lights up. I guess I could buy a voltmeter to see how much of a charge the battery has. Any other ideas?
Old 12-11-2008, 03:51 PM   #4 (permalink)
Yes, sounds increasingly like the clamp bolts aren't done up tight enough; so your low-current bits get good service (interior lights) but you don't move any charge into the battery and your high-current bits don't do so well.
Old 12-19-2008, 08:50 AM   #5 (permalink)
I had to have it towed to the dealer. I ended up needing a new key and the EIS. $1000 later and the car is running. Seems to be a problem from 2001-2003.
'86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190 Class 5 01-31-2009 08:09 AM
Smart Key Combination to Turn off Turn Signals Magic Man General Mercedes-Benz 0 09-10-2007 09:04 AM
2002 CL600... Need New Wheels... Fan2zee W215 CL Class 4 01-27-2007 07:49 PM
HELP!! WHICH ONE TO GET CL600 2001 or 2002 M_city W215 CL Class 3 11-01-2006 08:08 PM
turn the key and dash lights turn on, no power to starter bob richards General Mercedes-Benz 4 01-13-2006 07:48 AM
