Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 08-31-2008, 12:28 PM   #1 (permalink)
Date registered: Aug 2008
Angry 2000 cl500 all sorts of problems
I need help after just buying this car I am pretty cheesed off after p/x ing my immaculate r129 I dont have any speakers on the left hand side working and no rears except the sub also the ec light on the climate panel cant be switched off which means no aircon could some1 please give me some kind of idea as i could really do without throwing endless amounts of money at this car...
darylyoung is offline   Reply With Quote
Old 08-31-2008, 02:27 PM   #2 (permalink)
Premium Member
patbriandar's Avatar
Vehicle: W-220 S-600L 2000
Premium Member
Hi,
As regards your A/C (ec light staying on). This is because of a fault logged in the C/Control ECU. It could be anything but the most common thing is a faulty Evaporator sensor. (located in heater box). Once repaired the faullt will have to be cleared before system will operate again.
Not too sure about the speaker problem, but on the RHD models we had a lot of problems in the footwell of the passenger side, which caused havoc with the electrics(corroding connectors). I have also heard of problems with the Command units (radio unit)
Hope this helps some.
patbriandar is offline   Reply With Quote
Old 08-31-2008, 02:52 PM   #3 (permalink)
thanks for that il give it a try the speaker problem is strange as o/s/f works fine dash speaker works fine and so does the sub so hope its not the command unit?? dont suppose you know if the rear speakers are on the shelf do you? I have read somewhere that they are in the rear of the front doors.
Old 08-31-2008, 02:54 PM   #4 (permalink)
Premium Member
Premium Member
I'll have one in the shop tomorrow, I'll check and let you know.
Old 08-31-2008, 02:58 PM   #5 (permalink)
magic thanks very much i can see this cars gonna be a nitemare to my cash flow shuda maybe stuck with the sl!!!! guess they dont make them like they used to.
Old 09-04-2008, 07:26 PM   #6 (permalink)
Please see my reply in your other post as to fixing the speaker problem. I had the same problem.
Pronto is offline   Reply With Quote
Phone options for 2000 CL500 RogerNOrris General Mercedes-Benz 0 02-16-2008 05:14 AM
would this fit a 2000 cl500 ? mercedesclwhip W215 CL Class 0 02-13-2008 10:52 AM
Door electric problems CL500, 2000 roni_9999 W215 CL Class 3 02-09-2008 10:05 PM
2000 Cl500????? ccrispy General Mercedes-Benz 3 05-29-2006 11:02 PM
audio problem on 2000 CL500 laigool Audio & Telematics Forum 1 05-16-2006 05:32 PM
