Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 08-17-2008, 07:18 PM   #1 (permalink)
Date registered: Apr 2007
Vehicle: 96 SL 320
ABC Pump Tank Location?
Hey fellas my ABC warning lamp light came on and the system was running on limp mode. I believe I may have to add more oil to my ABC pump tank.
Does anyone know where this pump tank is located and does it require a special type of fluid or regular oil? Thanks in advance.
BTW its a 2003 CL 500.
Black on Black is offline   Reply With Quote
Old 08-17-2008, 10:13 PM   #2 (permalink)
calgary's Avatar
Vehicle: 2001 CL500
Powersteering and ABC pump oil reservoir are the same. Special (expensiive) oil is required. Do not use motor oil.
calgary is offline   Reply With Quote
Old 08-18-2008, 11:30 AM   #3 (permalink)
Date registered: Feb 2005
Vehicle: 1999 SL500 Sport & 2003 CL500 Sport
The power steering fluid is :
"Pentosin CHF 11S (MB part # BQ132001)/Q-1-32-001.
'99 SL500,'03 CL500
reddog is offline   Reply With Quote
Old 08-19-2008, 03:39 PM   #4 (permalink)
Vehicle: 96 SL 320
Thanks for the quick replies fellow forum members.
abc pump replacement 2003 s600 W220 S-Class 28 05-28-2008 08:28 AM
Relationship between suspension pump and ABC rkilgo W220 S-Class 2 03-05-2008 04:25 AM
Relationship between suspension pump and ABC rkilgo The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 03-04-2008 05:45 PM
ABC/PS pump leaking causing ABC suspension severe drop 2003 s600 W220 S-Class 15 08-21-2007 02:46 AM
2002 CL500 ABC Pump replacement alexgreggs W215 CL Class 0 09-05-2006 05:52 PM
