Hi
I have a problem with my car when I leave the car parked after one or two days is lowered on the front right,
I changed the shock-absorber and the valve but nothing to do Lowering forever.
Can somebody help me?
this might be a common condition there might be nothing wrong with your car, if it comes back up after you run it and no hydrofluid is leaking any where I wouldn't sweat it. good luck
It's normal for the car to settle. When it's warm, mine will settle to the ground in only 2-3 days. When you start it, allow the motor to run a while. Once the Tachometer reads <1000 rpm, put the transmission into Neutral. The car will rise to normal ride height. If it doesn't, the display will display that there is an ABC problem and will need service. If that is the case, a common issue is the struts. They typically last around 70-80,000 miles (130,000 km). Look under the hood or around the wheel - it is possible that there is hydro-fluid soaking around components in there, indicating a leak?
best,
-dan
Boston, USA
2001 CL600 Designo Silver
97 S500L (Bordeaux over Parchment, 4-place seating, Sony XES Z50, door curtains, more wood, W220 17" wheels)
