Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 07-25-2008, 02:32 PM   #1 (permalink)
Date registered: Jul 2008
Speed Limiter on my CL65
I have a 2006 CL65. Everyone that knows about it, knows that it is a monster. I would like to get the 155 MPH restriction taken off. All this power (and extra money) for what? So it can sound louder and reach 60 before a CL500, but in the end can only do the same speed as a 500? What type of place should I go to, to get the limiter taken off? Do Mercedes-Benz service centers do that?
Because I'm going to need it to go as fast as it can.
Has anyone else got their limiter taken off? If so, were there any problems etc... And what is the general cost?
Mercedes-Benz ///AMG is offline   Reply With Quote
Old 07-25-2008, 08:50 PM   #2 (permalink)
Date registered: Nov 2002
Vehicle: 560 SEC Supercharged(sold), E55 AMG, Renntech CL600 Bi-turbo, Porsche 928
Renntech or Kleeman. I'd go with Renntech.
Supercharged SEC is offline   Reply With Quote
Old 08-24-2008, 10:56 PM   #3 (permalink)
star500e's Avatar
Date registered: Feb 2003
Vehicle: 1997 S500 & 2001 CL600
Send a message via ICQ to star500e Send a message via AIM to star500e Send a message via MSN to star500e Send a message via Yahoo to star500e Send a message via Skype™ to star500e
He's right - RENNTech and Brabus (I didn't know that Kleeman did it) are probably the few that have bothered figuring out those infernal ECUs. Here's the problem and it's twofold: a- the ECU is hard-fixed into that board, which is inside the black box, so messing with it means you have to access it via the CANbus, b- it's not documented. If you have the software to access ECUs (it's out there and apparently goes via the OBD connector or some kind of proprietary connection somewhere, I don't know) you can see how the ECU behaves under various conditions. It turns out that these big shops spend a lot of time and money to just figure out and reverse engineer where the various limiters are (yep, there are usually several as I am told) and then engineer code to get around them. The most reliable way to get around them is to do a chip.
Now, when you do this, you'll also get more HP (like you need it). I have heard some stories that the transmission in these cars really isn't designed to take much more power and abuse than it does in a CL65. That may lead to a situation like what happened with the Olds 442 back in the day: dropping the transmission when you stomp on the gas. Er, at least the potential for some transmission issues down the road.
best,
-dan
Boston, USA
2001 CL600 Designo Silver
97 S500L (Bordeaux over Parchment, 4-place seating, Sony XES Z50, door curtains, more wood, W220 17" wheels)
star500e is offline   Reply With Quote
Speed Limiter abm101 W220 S-Class 0 05-15-2007 04:55 AM
CL65 - unstable at speed Lotus1 General Mercedes-Benz 11 07-10-2006 04:58 PM
Speed Limiter, scottcardwell R230 SL Class 7 02-21-2005 12:10 PM
speed limiter pokerface x W203 C-Class 9 03-02-2003 02:42 PM
I read that the SLK320 has a speed limiter that limits maximum speed to 129mph but... Dean R170 SLK Class 6 06-11-2001 01:08 PM
