A few months ago, I noticed that my car was leaking some fluid in my driveway, turns out that it was my ABC fluid and the right passenger was extemely low, body was almost on the ground. It turns out that it was because of a busted seal, so i replaced the seal and refilled the fluid and when i started the car, it popped back up.
Now, after changing the oil myself, i was lowering the jack and it came down pretty fast, since then the right passenger side wheel is sitting low and I have an error message saying there is something wrong with the ABC system. There is no fluid leak, and I can't raise or lower the car using the switch inside. I already had the abc hose that was recalled replaced. I can't figure out whats going on and now the right side is sitting lower than the left. Does anyone know what the problem is and how to fix it? And is there anywhere else besides the dealer where i can have this fixed?
I believe the system has to be flushed and then the `rodeo ride`` has to be performed.(at the dealership) To just add the oil probably will not do it...IMO
thanks calgary, thats what i figured too. the funny thing is when i call the dealer and ask them about the "rodeo ride" they have no idea what i'm talking about.
What, no idea what you are talking about? I thought the highest number of Benzes sold is in California, I would have assumed your dealers would be better informed than ours up here. Canada only gets a small percentage of MBs compared to the US of A.
I have a lot of respect for the technicians that work on these "ueber-engineered" cars, and can actually figure out how to fix them.
