Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
View Poll Results: Have you changed your tranmssion fluid?
NEVER 3 50.00%
Flushed 0 0%
Flush and Filter 3 50.00%
Voters: 6. You may not vote on this poll
Old 06-04-2008, 12:06 AM   #1 (permalink)
Date registered: May 2008
Smile My experience with transmission flush
My 2003 CL55 AMG has given me some stuttering shifting, as I have read describing as "humming" during light accerlation, and "hard vibration" during shifting. It has "lock-release-lock-release" from the torque converter. This was very reproducible, and it sometimes feels and sounds like I'm missing a tooth in my transmssion gear! I am sure I was looking at a new transmission.
Stealer has informed me that the transmission fluid was not a servicible item, and there is no way to drain the complete fluid correctly. If there is a problem with the transmission, I'm looking at a NEW one... $6,500. After reading the internet, I have decided to get a transmission fluid service anyways.
To giving the ending away, the transmssion now shifts SILKEN SMOOTH. ABSOLUTELY like NEW!!! But to get to this point, I have learned about a few things:
1. Transmission flush by itself may not be good enough, since it doesn't get the filter out the way, and may stir up a lot of junk at the pan.
2. Dropping the pan is not enough, because the Torque converter is not drained.
3. I can't drain my torque covnerter, because it's is sealed, and there is NO drain plug on my model (this is confirmed by several sources)
I have gotten several quotes for transmssion flush and service and filter service. It ranged between approx $300 to $650.
I went with a reputable german car shop, and they had quoted me a $280 if my torque converter had a drain, and will be $360 if it doesn't. What they told me did, is that they opened the transmission fluid line, and bled the system almost 90%. The old fluid can not be life-time... it didn't look right and didnt' smell right.
After 4 hours at the shop, and them working on it diligently, my transmssion now feels simply PERFECT! Worth EVERY PENNY!!!
cl55_wil is offline   Reply With Quote
Old 06-04-2008, 12:51 AM   #2 (permalink)
~BANNED~
linh's Avatar
Vehicle: 06' CLK 500 Cabrio, 01' CL 55, 01' CLK 430, 04' Civic
The best way to do this is fine a shop with a tranny flush machine. With this machine, they disconnect the fluid line that go into the front cooler then connect their machine to the line. They then start your engine and let in run around 1000-2000 RPM, this allow the tranny fluid to circulate the old fluid into their machine and out with the new fluid into the tranny. Then they reconnect all the fluid line back, go through shifting all the gears and then top off the fluid. The only requirement is, you have to have a dipstick to check the fluid.
linh is offline   Reply With Quote
Old 06-06-2008, 05:45 PM   #3 (permalink)
manymercsmike's Avatar
Date registered: Aug 2006
Vehicle: CL500, CL500, 190E 2.6, 420 SEC, 350 SL
MB maintain that the 5 spd box is "sealed for life" - however I have two cars fitted with similar boxes - having just seen the ATF fluid out of my C140 - I recommend you change it semi-regularly - the fluid out of my C140 was manky!!!
(that's Scottish for filthy)
Current metal:
2002 (C215) CL500 (Batmobile), Obsidian Black, 54k miles
1997 (C140) CL500 (Bismarck), Emerald Black, 134k miles
1991 (W201) 190E 2.6 Sportline (Blake), Almandine Red, 133k miles
1990 (C126) 420 SEC (Bruce), Astral Silver, 111k miles
1978 (R107) 350 SL (Boabby), Signal Red w/ silver hardtop, 115k miles
manymercsmike is offline   Reply With Quote
Should I get a transmission flush? roybotnik W210 E50 AMG, E55 AMG 14 11-15-2007 04:50 PM
Transmission, to power flush or not Teutone W126 S,SE,SEC,SEL,SD,SDL Class 4 03-27-2006 10:49 AM
Transmission Flush NorCal_ML320 W163 M-Class 5 03-07-2006 11:31 PM
transmission flush jtbeche W208 CLK Class 6 01-21-2006 05:21 PM
Transmission flush? AlBoston W163 M-Class 2 04-27-2003 11:08 PM
