Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 05-14-2008, 05:31 AM   #1 (permalink)
Date registered: Jul 2003
Vehicle: 2003 ML350
left rear tire wearing faster than right
Hi ,
i have a 2001 cl500 sport. had new tires at around 14,000. now at 22,000 miles, noticed
left rear tire is smoothing out compared to right. you can still see tread design on right
tire, but on the left tire the tread is almost gone. wear is even on the left tire. front tires
are still in good shape. in between miles i've had the rear left strut replaced due to leak and
also had the front and rear axle control valves replaced due to right side of car dropping.
is it normal having left rear tire wear faster than the right on these cars? this is my first rear
wheel drive car so i don't have any experience. i don't burn out or spin out, i always have
stability control on. wear is even on the tire so i don't think my alignment is off and tire pressure is good. i'm hoping its not the suspension. please tell me this is the norm.
another question i have is the torque more in the right or left wheel or the same for both.
current tires i have are the dunlop 9000 sport and wheels are the original amg. sorry for the long post. thanks for reading and any input in this matter is very much appreciated.
ps for orientation left/right side, this is if you stand in front of the car.
leontr44 is offline   Reply With Quote
Old 05-22-2008, 01:01 PM   #2 (permalink)
manymercsmike's Avatar
Date registered: Aug 2006
Vehicle: CL500, CL500, 190E 2.6, 420 SEC, 350 SL
The fact that you've had the left shocker changed on its own, and not the right one at the same time, suggests to me without a doubt its your shocks.
Unless you've had the tyre pressure way too high for any period of time on the left one, I'm 100% sure it's your shocks. Normal practise would be to always change them as a pair (on a CL that's expensive tho).
Either that or something strange is up with your ABC system causing an imbalance in the application. But I'm convinced it's your shocks (or your left one in particular) having different characteristics. Tyre wear should be even for both rears, and for both fronts.
Current metal:
2002 (C215) CL500 (Batmobile), Obsidian Black, 54k miles
1997 (C140) CL500 (Bismarck), Emerald Black, 134k miles
1991 (W201) 190E 2.6 Sportline (Blake), Almandine Red, 133k miles
1990 (C126) 420 SEC (Bruce), Astral Silver, 111k miles
1978 (R107) 350 SL (Boabby), Signal Red w/ silver hardtop, 115k miles
manymercsmike is offline   Reply With Quote
Rear Left Tire Balding on Outsides and tranny issue- the double wammy leetyler W124 E,CE,D,TD Class 1 06-07-2006 03:19 PM
On your G does the front tire rear wear out faster or the front? blau G-Class 5 12-04-2005 12:31 AM
left tire is wearing down quicker than the right slknow R170 SLK Class 3 07-22-2005 09:07 AM
Rear Tires Wearing out R*A*P*I*D*L*Y vdufault W124 E,CE,D,TD Class 11 07-16-2003 01:03 PM
Is it true that the passenger rear tire wears out faster than any other tire on ML430 & ML... MBLady W163 M-Class 6 07-10-2003 05:07 PM
