Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 04-21-2008, 07:40 AM   #1 (permalink)
Date registered: Mar 2008
sudden drops.....normal?
Sometimes while my car (02 cl500...51,000 miles) is turned on and in the Park position I will feel a sudden drop like I have hydraulics or something. Is this normal?
As an example, I went to pick up my sister from work and while waiting outside, I felt the car drop.
Another time, as soon as I shifted the car to "drive" the car dropped again.
This also might me my perception, but sometimes when I walk around the car it seems as if one side is higher then the other. I never actually measured the disatnce from the wheel to the fender but it seems like every other day one side or tire/fender is higher then the other....i dunno
Looking at the service history of the car, the ABC has never gone bad...(yet)
mike1978 is offline   Reply With Quote
Old 04-21-2008, 08:54 AM   #2 (permalink)
calgary's Avatar
Vehicle: 2001 CL500
This problem appears to be quite common with the ABC system. Leaky valve? Pump problem? I would suggest to have it checked out asap - (My pump let go on an out-of-town trip - slow driving home with the warning light on - )
calgary is offline   Reply With Quote
Kucinich Drops Out... Jayhawk Off-Topic 46 01-29-2008 08:07 AM
Drops of water adman0468 R171 SLK Class 7 06-17-2007 01:58 PM
Sudden Voltage Drops faisal300ce W124 E,CE,D,TD Class 3 05-15-2007 01:46 PM
vacuum drops with AC on! 2manyoldcars W201 190E, D-Class 0 07-01-2006 10:40 AM
Is it normal? My SLK accelerates a bit faster than normal after… funfun R170 SLK Class 2 11-06-2003 07:49 AM
