Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 04-20-2008, 01:32 AM   #1 (permalink)
Date registered: Apr 2008
HELP! Car stalling while driving...
Hello all!
I have a 2001 CL55 AMG which recently experienced a bunch of issues... and a new problem just appeared today. Since the dealer of my region is a complete moron, i will need some help from here...
The problems started one month sago, when a bright red signal appeared on the dashboard "ABC drive carefully"; at this stage the car's suspension were kind of weird (one bump on the road and the car would literally jump...) After one week, the car's height dropped dramatically.
With the help found on forums, I decided to change the ABC pump only (the dealer wanted to change the dampers and the airmatic pump (airmatic on a CL?)). It was changed last week, and it solved the problem.
But a new problem appeared 3 days ago. I was driving at around 80km/h (50MPH) at around 2000rpm when the car suddenly stalled. Frightening, since the direction became as well extremelly difficult to turn (steering pump off since the engine stalled I guess?).
I stopped the car, I started it right after; no problem, the car is behaving as nothing happened. I continue my ride; 10 minutes later, the throttle is not as responsive as before, and i feel a big loss of power. The white error message "ESP visit workshop!" appears intermittently while driving as well. One minutes after, the car is stalling again when I'm driving at 120 km/h (80mph)! and around 3000 rpm...
Then I had to go back home with an engine which is stalling every 5 minutes, blinking white error message "ESP visit workshop!". I stop the car, i start it immediately, drive 5 minutes, stalls, etc etc.
Today, the car had the same problem again, but to a bigger extent. Engine stalled when it was still cold, 3 minutes after driving. When I try to start it again, it stalls immediately after ignition. (i.e. it starts then stops 3 seconds later).
I'm getting my car towed to my useless dealer today.
Is there any link between the replacement of my pump, and this stalling problem?
After some reading on the forums, I was thinking that the crankshaft position sensor might be faulty. Any suggestions?
vgarcin is offline   Reply With Quote
Old 05-19-2008, 08:11 AM   #2 (permalink)
Date registered: May 2008
Car stalling issue
I experience the same problem over the weekend. Thank God it stalled while I was on a service street and not the freeway. I had to tow mine to my dealership that day since it would not start again after it stalled. This is not good......
Everett is offline   Reply With Quote
Car Almost Stalling On Turns TC_TRIGGER General Mercedes-Benz 7 09-08-2006 06:31 PM
Car is stalling Kingorcus W126 S,SE,SEC,SEL,SD,SDL Class 3 06-27-2006 10:08 AM
[:(]Car stalling when accelerating, please help daniyar79 W124 E,CE,D,TD Class 0 09-23-2004 09:10 PM
ML Stalling while driving gary1378 W163 M-Class 8 03-20-2004 02:57 AM
Car Stalling Frequently Chupper W124 E,CE,D,TD Class 9 02-02-2004 07:39 PM
