Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 04-15-2008, 11:06 PM   #1 (permalink)
walebay's Avatar
Date registered: Aug 2005
Vehicle: 2000 CL500
Send a message via AIM to walebay
***Check Engine and Gas Tank issue***
Hello All,
This just started a few weeks ago and it happens randomly.
Here is the issue when I'm driving all of a suuden I hear a tone and on my dash it states that my gas tank is open, when it's not then the Check Engine light comes on. I've tried tighting the cap etc... still nothing....
Has anyone experienced this before...
Thanks
CL500
walebay is offline   Reply With Quote
Old 04-16-2008, 06:48 AM   #2 (permalink)
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, S420
You probably lost the pressure in the fuel tank. Have you read the code?
One easy way (at least for now) is to flip the rubber in your gas cap around. I doubt it'd help much but it's worth a try. Again, try reading the code first.
lnguyenh is offline   Reply With Quote
Old 05-13-2008, 08:19 PM   #3 (permalink)
Date registered: May 2008
Vehicle: Mercedes Benz E320 2004
Same thing happens on my 04' E320.
Lakersfan201 is offline   Reply With Quote
Check engine light on due to Tank Cap Loose gahmed General Mercedes-Benz 21 07-27-2007 12:19 PM
Check Engine due to Gas Tank Cap loose.. gahmed W220 S-Class 1 07-26-2007 12:25 PM
Full tank of gas causes rough engine performance TobiasSanDiego W220 S-Class 3 11-26-2006 10:09 AM
Check Engine issue- 2001 ML320 dss52487 W163 M-Class 11 01-02-2006 11:37 PM
Noooooooo!! Check Engine light came on.... any known issue? Dan R170 SLK Class 14 01-30-2001 06:19 AM
