Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 04-11-2008, 04:49 AM   #1 (permalink)
Date registered: Apr 2008
cl500 CD problem, NO MAGAZINE
Hello,
I got the old cl500 from my friend, but it has got a problem shows "NO MAGAZINE", anyone can help me? Can you also show me where is the CD changer of 6 CDs, I cannot find that.
Thanks alot
ldquang201 is offline   Reply With Quote
Old 04-11-2008, 01:18 PM   #2 (permalink)
Date registered: Mar 2008
in the trunk. lift up the mat in the trunk. Its on the left hand side. the cd changer magazine is probably missing
mike1978 is offline   Reply With Quote
Old 04-11-2008, 04:02 PM   #3 (permalink)
calgary's Avatar
Vehicle: 2001 CL500
Hi-Tech stuff with these Mercedes-Benzes. Everyone laughs when I show them where my CDs are hidden.......
calgary is offline   Reply With Quote
Old 04-11-2008, 10:20 PM   #4 (permalink)
Date registered: Jan 2008
Vehicle: 2000' CL500
Take out the cartridge and put it back again. If it doesn't work, repeat for a couple more times.
My CD changer had the same problem but it went away after I took out the cartridge and put it back.
Jon
Baby ///M3 is offline   Reply With Quote
Old 11-05-2008, 07:03 PM   #5 (permalink)
Date registered: Oct 2008
No Maganizwe fix
Originally Posted by ldquang201 View Post
Hello,
Thanks alot
Hi
I have a 2001 Cl500 and I had the same problem a couple of months ago. I tried to put in/out several times but no luck.
If you remove the side cover you will see a couple of screws holding the cd unit. If you remove these, you can unplug and plug from power and see if when tou turn the cd on, if the palstics gears move. If not, tehre is a little lever, you can presente and "reset" ( sometimes gets lock) and with that the gears will move again and the cds will be detected.
Hope this helps
rantbenz is offline   Reply With Quote
Old 11-05-2008, 11:09 PM   #6 (permalink)
Date registered: Aug 2007
Vehicle: 2003 CL500
Where is this lever? It resets the cd changer?
ALi
goliath27 is offline   Reply With Quote
Old 11-06-2008, 09:39 AM   #7 (permalink)
ALi
I should say better, it resets the whole arm that looks for the cds.
The cd has 4-8 screws around that holds the metallic cover case.
If you remove the screws ( with previously all disconnected ) you will see a little white lever that touches two little buttons.
With the cover out, plug again the power cable and turn on the cd from the radio console. Now, press any of these little buttons and you will see the unit starts and checks each of the 6 cds .
After that, the magazine will be recognized and you can put/play a cd to see if works.
Now turn the cd off, unplug the power, put the case back, and assembly the unit one more time.
Test it again to be sure the cd still works and after that just put it on the trunk again.
note : be carefull when you are removing the cover, due to there is a flat bus connector on the back that is very fragile, remove gently.
hope this helps
Old 11-06-2008, 11:32 AM   #8 (permalink)
Vehicle: 2003 CL500
Damn, I was hoping it was just a open and push reset. Seems like it takes more labor. How long do you think the reset will last before the problem re-occurs
ALi
Old 11-06-2008, 12:56 PM   #9 (permalink)
ALi
It is more the time you spend taking all covers out that what really fixes the problem. I think the arm gets stuck and when you press the little button unlock the arms and the magazine works again. I did this since earlier this year and so far no problem, cd working perfect. It took me around 1.5 hours to do this.
Old 11-12-2008, 06:07 PM   #10 (permalink)
BISHOP13's Avatar
Date registered: Nov 2008
Vehicle: 02' CL500 99' ML320
Send a message via AIM to BISHOP13 Send a message via Yahoo to BISHOP13
SAME THIGN HAPPEN TO ME WHEN I FIRST GOT MINE AND ALL I DID WAS PUSH DOWN A LITTLE HARD A FEWTIMES ON THE CD HOLDER AND IT POPED IT OUT WITH TQAPING EJECT... HAPPENED AGAIN A FEW MONTHS LATER.. DID SAME THING AND IT WORKS....
BISHOP13 is offline   Reply With Quote
CD changer magazine problem 99 C-Series starviper Audio & Telematics Forum 0 02-14-2008 06:02 PM
audio problem on 2000 CL500 laigool Audio & Telematics Forum 1 05-16-2006 05:32 PM
1999 CL500 window closing problem LBVIC W140 S-Class 8 09-21-2005 11:42 PM
2001 CL500 w/ Audio Problem tcounts W215 CL Class 1 05-23-2005 01:49 PM
Do you have the following problem with your CL500??? ranarana W140 S-Class 6 04-17-2004 05:19 AM
