Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 03-05-2008, 09:54 AM   #1 (permalink)
Erotic1's Avatar
Date registered: Jun 2005
Vehicle: 2001 CL500 Lorinser
Remove Rear Sub Woofer
Has anyone tried or successfully removed the rear sub on the CL500. I'm close to cutting the freakin' thing out with a Sawsall. There has to be a reasonable way to get this woofer out... Does anyone have any tips?
Thanks!
Erotic1
Erotic1 is offline   Reply With Quote
Old 03-05-2008, 10:54 AM   #2 (permalink)
Vehicle: cl500
you need to remove rear seats & center console in the rear seat, its quite easy. take the panels either side of rear self off (lever out airbag sign theres a screw behind) then they will unclip. you are then able to pull forward your rear shelf and access your sub!
beacham is offline   Reply With Quote
Old 03-05-2008, 11:20 AM   #3 (permalink)
Erotic1's Avatar
With regards to removing the rear seats. The bottom part pops right out. Then there are two bolts on the outer sides of the back rests. After I remove those the back rests feel lose but i can not figure out how to get the back rests to "unhinge". Do they slide out? Is there pressure points like the bottom part?
thanks
Old 03-05-2008, 01:49 PM   #4 (permalink)
Vehicle: cl500
if i remember correctly there are also bolts by the center console, the console is just clipped in place and you need to remove it to get at bolt/ bolts. then you just lift seat up and out.
Rear Deck Woofer Problem skiplanes General Mercedes-Benz 0 08-08-2007 06:34 PM
how to remove rear bumper? ProV1x W210 E-Class 3 04-29-2007 07:55 AM
help with s320 rear woofer molding removal unSobill320 W140 S-Class 3 09-25-2006 01:03 AM
How To Remove Rear Bumper? Gate1way2 W208 CLK Class 2 06-29-2005 01:11 PM
Is it possible to remove the TeleAid module and install a second sub-woofer..? AC_ML W163 M-Class 3 06-18-2003 10:49 AM
