Hello guys, I am an owner of a 2000 E320 Designo W210 and maybe purchasing a set of 2006 CLS500 AMG wheels for my W210. The Mercedes part # is 2194011202 for the front & 2194011102 for the rear. I was wondering if someone here would be kind enough to tell me what the offset of these wheels are. I called the owner and he does not know nor how to look it up. Below is the picture of the wheel. I would really appreciate all and any help from you guys. These are 18"
Thanks in advance!
If these are the original wheels that came with the car then the wheel offsets should be stated in the vehicle owners manual. Tell the owner to look in the back of the owners manual under technical specifications. Hope this helps.
heya! front ET25 rear ET28
Wheels spec is here: http://www.mercedes-benz.de/content/...yp_219_AMG.pdf
The C219 spec of 18" AMG IV fits the 210. New bolts needed M12x1.5x24R14. I have a picture of the wheels on a 210 here:
Please note that these wheels are the 8.5ET25 and 9.5ET28 C219 AMG IV versions, fitted with 235/40 and 265/35 tyres
CLS wheels have a different offset than the CL.
I put 20's on mine 8.5 wide (all 4 so I can rotate them for better wear) with a 35mm offset and they work nicely.
Call Discount Tire- They can give you the info out of a book they have.
