Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W215 CL Class
Old 04-14-2004, 12:36 PM   #1 (permalink)
PFC
Date registered: Apr 2004
Swaping out CL tail and head lamps with the 2004 type
Have any of you swapped out your head and tail lamps with the 2004 type? Any problems,and approximate costs if you have. Thanks
PFC is offline   Reply With Quote
Old 05-03-2004, 06:42 PM   #2 (permalink)
Date registered: Dec 2003
RE: Swaping out CL tail and head lamps with the 2004 type
They dont exactly fit, you need to get a specialized kit designed for the older cars.
E V12 Nerd is offline   Reply With Quote
Old 05-17-2004, 04:52 PM   #3 (permalink)
Date registered: Aug 2003
The '04 tail light lenses should be an even swap out. The headlights are slightly different.
The M-B P/N's for the tail light lenses are:
R 215 820 0766
L 215 820 0866
The lenses are $187.75 ea from M-B.
They are also available for $279.00 for the pair plus $70.00 freight from www.ERNSTCARDESIGN.de in Germany.
You can e-mail him at oe@ernst-vewa.de.
He has bi-xenons for 220' and 215's.
BTW, you'll need your friends fluent in German, but he will communicate with you by e-mail in broken English!
GCalo is offline   Reply With Quote
Old 05-18-2004, 09:01 AM   #4 (permalink)
Date registered: May 2004
I recently swapped tail lights in my 2000 to 2004 style. I now have no brake lights because the new style brake lights are LED. Is there a fix for this ???????? HELP!!!!!!!
JohnnyCL500 is offline   Reply With Quote
Old 05-18-2004, 10:20 PM   #5 (permalink)
I can translate the German if you need me too.
Old 05-28-2004, 08:22 PM   #6 (permalink)
Vehicle: 2003 CL 55
Johnny, look on ebay or any auction for a used set of 2002 cl lights and they have the led that just needs to be removed and added to the 2004 lights. You might even have them on your 2000. I had a 2002 CL 55 before the 2003 I just got and the lights switched over no problem, I just had to remove the leds and add them to the new set. Good luck.
robert_provost is offline   Reply With Quote
