Just purchased a 2010 CPO E350 Sedan -Sport package...
Awesome car...
I have a couple questions about the car.
1) The sound system with ipod plugged in, will automatically switch back and forth between ipod and radio. Anyone run into this?
2) Power steering seems noisy-Car has 32K on it.
3) Front windows are touchy: If I hit the down the window goes down as it should. If I hit button while it's rolling down, the window stops as it should, but if I go to roll it up it still goes down? If I stop it and wait 5 secondss it goes back up..Is this normal?
Welcome! Since you have a CPO I would highly suggest using that before it runs out.
Make sure that your Ipod is plugged in fully and it clicks. If not it will not receive correctly and the radio will come on or it will go silent. Make sure it is tucked away safely as well.
The power steering should be silent and effortless. What type of noises are there?
My 2010 E350 windows do the same thing. Not sure if this is normal or not, but it sucks if you want to change direction of the window quickly (like when it is raining).
I think you need to establish the window stop points. To do this, start with the windows fully closed. Then hold down the switch to open them, but do not use the auto down portion, just the slight touch. Continue to hold the down switch for 5 seconds after the window completely opens. Then do the same for closing the window, hold the switch for 5 seconds. This will set the limits for the window. Test by fully opening and closing the window with the auto mode. If this doesn't work, then you might have a bad switch.
I had the door-window control module programming updated today.
So far it works good.
I had the TCM programming done as well-big improvment
