Command System upgrade - Page 4 - Mercedes-Benz Forum
post #31 of 37 (permalink) Old 01-10-2015, 01:32 AM
Date registered: Nov 2008
Vehicle: 2015 Mercedes Benz CLS400
Quoted: 5 Post(s)
Send a message via Skype™ to imilad
Hello guys...
I just purchased my 2010 w212 about two weeks ago.. I was bummed when I noticed that the BT AUDIO was not showing in the menu.. Did some reading online and discovered the "engineering menu" .. With lots of excitement I enabled it. But came to great disappointment as every time I would try to connect it would only display with "Authorization Unsuccessful"
Did some more research...
enabling BT AUDIO from engineering mode will allow you to externally authorize your phone, but what it does is, de authorize BT PHONE functionality.. In other words you can only have either or. I was testing all of this from my iPhone 6 so I knew the issue was not from my phone as it has the latest BT 4.0LE chip in it.
Called up the dealer and made an appointment. Got super lucky as I realized my car still had a cert pre owned warranty until next month. picked it up today and both Audio & Phone is working.
Point is,, It will only work with the software upgrade on the command unit...
Now I am trying to go couple steps further to get iPhone mirroring onto the unit.. If anyone has any suggestions I would appreciate that allot.
Thank you
imilad is offline
post #32 of 37 (permalink) Old 01-11-2015, 01:01 PM
Date registered: Jan 2015
Vehicle: 2011 E350 Wagon 4matic
switch to new blackberry Passport. Get $500 toward new phone that works with the car. Sorry just had to. Die hard BB customer
BERNIETHEGERMAN is offline
post #33 of 37 (permalink) Old 01-04-2016, 02:27 PM
Date registered: Mar 2008
Vehicle: 2010 ML 350 Bluetec 4Matic
Quoted: 121 Post(s)
Does anyone know if there is a firmware update to add audio streaming in MY 2009 and 2010 164 ML. Thanks in advance.
james.calton1 is online now
post #34 of 37 (permalink) Old 01-05-2016, 08:28 AM
Date registered: May 2013
Originally Posted by imilad View Post
Hello guys...
Thank you
WHat are you trying to mirror?
TXDiesel22 is offline
post #35 of 37 (permalink) Old 04-09-2016, 10:09 PM
Date registered: Mar 2012
Vehicle: 2007 CLK 350 convertible, 2010 E350 4matic
Quoted: 8 Post(s)
I just got the Samsung Galaxy S7 Edge and this phone pure and simply does not like to cooperate with the bluetooth in the COMAND. I do not believe my car had the COMAND firmware upgrade yet. First off, I can only successfully pair the phone to the COMAND deck only if all other authorized phones have been deleted from the list. Secondly, it works fine when it is initially paired. However, once I park the car, turn off the engine, and the bluetooth automatically disconnects, it will never connect again when I go to start up the car. The phone tries to connect to COMAND, but then the connection fails and an error message pops up on the phone screen that the phone was unable to communicate with the car's bluetooth.
The only way that I can get it to pair again is to unpair the connection from the phone with the car off, turn off bluetooth, then start the car and de-authorize the phone from the COMAND bluetooth. Once the phone is de-authorized, I can then turn on bluetooth on the phone and start the pairing process again from scratch. This is a ridiculous 5-10 minute process to have to go through every time you get in the car and want to drive somewhere and be able to make phone calls hands-free. It's not an issue with the handset because it works fine with a Pioneer head unit in my son's car, and works fine with bluetooth headsets and speakers. And I've paired and used a number of different phones for phone audio (bluetooth phone calls) and never had any issues, which started with the HTC Rezound and almost every version of Samsung phone (Galaxy S3, S4, S5, Note 2, Note 3, Note 4 and Note 5).
jseah is offline
post #36 of 37 (permalink) Old 04-10-2016, 07:11 PM
Favog's Avatar
Date registered: Mar 2014
Vehicle: 2014 E250
Quoted: 55 Post(s)
My iPhone 5 plays nicely with COMAND in my 2014 E250. No complaints whatsoever.
Favog is offline
post #37 of 37 (permalink) Old 04-14-2016, 11:41 AM
Date registered: Apr 2016
Vehicle: 2010 e class cabrio
did you try this ?
10 Common Samsung Galaxy S7 problems and how to fix them
scroll to BLUETOOTH CONNECTION ISSUES
Ale
alezx is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W212 E-Class
2009/2010 COMMAND system upgrade from 2006 on CLS500 ???'s Help Please! The_Dream_CLS Audio & Telematics Forum 20 07-02-2012 12:22 AM
Does MB charge to upgrade the command system? BootyHunter57 W221 S-Class 10 05-26-2011 09:21 AM
Command System Upgrade dlynch4008 W220 S-Class 6 02-27-2011 02:52 PM
2009/2010 Command System Upgrade ???'s! Help Please! The_Dream_CLS C219 CLS-Class 0 10-13-2009 08:06 AM
COMMAND SYSTEM / SOUND SYSTEM '01 S500 robertindallas W220 S-Class 1 03-18-2008 05:04 AM
