Staggered Rims for 2012 E-350 4MATIC - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-10-2012, 11:13 AM Thread Starter
Date registered: Mar 2009
Vehicle: 2012 E-350 4MATIC
Hi Guys,
I'm pretty new to this forum and need help with this. I just purchased a 2012 E-350 4MATIC and was wondering if it's all possible installing staggered 19" rims on it without having any major issues being that this is a 4MATIC.
The rims I'm interested in installing have the following specs:
Front 19x8.5" with 42mm offset
Rear 19x9.5" with 44mm offset
Is anyone running a staggered setup?? Thanks in advance for the info.
Lorenzo
C300NJ is offline
post #2 of 4 (permalink) Old 01-16-2012, 12:24 PM
Date registered: Jan 2010
Vehicle: E 550 4 matic 2010
your overall diameter with the tire has to be spot on the same. I wouldn t..
Pick which rime fits front and rear and use the same all the way around,, this way all the tires will match.
2010 E550 4matic, AMG Package
cerbomark is offline
post #3 of 4 (permalink) Old 01-19-2012, 04:17 AM Thread Starter
i did a little research and you can stagger a 4matic but your overall diameter for the tires has to be the same (cannot exceed 0.3" between front and rear).
Is this true?
Thanks
C300NJ is offline
post #4 of 4 (permalink) Old 01-19-2012, 05:42 AM
what you said sounds possible but you have a 4 matic which puts power down to all 4 wheels so I don t know why you would want different tire sizes which may perform or grip differently. I m thinking you must be going for a certain look and think you can have an awesome set of wheels without chancing the function if you keep all 4 the same. Did you check with the dealer?
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W212 E-Class
    For Sale: 17" 2012 AMG Rims off 2012 C Coupe saurey W204 C-Class 11 12-02-2011 08:51 PM
    Evidence of Staggered Rims working great 4Matic S550 Pasqualino W221 S-Class 4 02-09-2011 07:05 PM
    4Matic Staggered Rims? Big D W220 S-Class 4 05-02-2010 04:37 PM
    17" staggered amg on 4matic wally_budz W210 E-Class 2 11-07-2005 10:15 AM
    17inchamgo monoblock 2 rims staggered on 4matic skislope96 W210 E-Class 2 06-04-2003 06:34 PM
