| Famous chirp replaced with something else
I usually get the famous chirp sound when starting to roll a bit, but after some runs last night, it becomes real bad, its not chirpping anymore but replaced with cracking sound, checked the clutch and I see no problem and the belt as it is quite tied, then I removed the belt and checked all the pulleys are ok smooth and not shaking, also I had the SC pulley bearing changed for about a year ago, so wheres the cracking sound came from? Am I cracking the SC? What test should I do to find out the problem?
