05 E55 "chirping" noise when downshifting - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz AMG Forums > W211 E55 AMG, E63 AMG
Old 08-03-2011, 10:13 PM   #1 (permalink)
Date registered: Jul 2011
Vehicle: 05 E55 AMG
Hello
Bought my E55 AMG about a month ago. It has 62k and was well maintained at the local dealership before it came to me. It seems flawless in every way and everything seems functional with a few electrical glitches that will be easily fixed. I have however noticed a kind of chirping noise when it downshifts into a lower gear when you accelerate while rolling along. Seems almost like a slight belt slip type of noise and not a metal clang or clunk. It shifts like butter and there are no malfunctions in its operation otherwise. Any ideas what this could be? Any thoughts are greatly appreciated.
Cheers, Jon
purplehayes is offline   Reply With Quote
Old 08-04-2011, 07:21 AM   #2 (permalink)
Date registered: Sep 2009
Vehicle: 2007 e63. Iridium Silver.
I beleive that many folks on other forums have discussed the infamous "supercharger chirp". Fairly normal occurrence for you e55 guys.
Check here:
chirping sound coming from the engine?? - MBWorld.org Forums
lawguy is offline   Reply With Quote
Old 08-04-2011, 11:43 AM   #3 (permalink)
EvoGuy's Avatar
Date registered: Dec 2006
Vehicle: 2004 E500 Wagon, 2004 E55 AMG
I have the same problem, from what I've heard there's nothing to worry about! I just got used to it.
EvoGuy is offline   Reply With Quote
Old 08-04-2011, 01:00 PM   #4 (permalink)
Vehicle: 05 E55 AMG
That's great info guys. Good to know it is very common and nothing tragic. Thank you for the link too. Didn't think of searching for chirping, lol! I can sleep better now.
Cheers
Old 08-06-2011, 10:42 AM   #5 (permalink)
Ike Luv's Avatar
Vehicle: 2005 Brilliant Silver E55 AMG
I notice it also, I have gotten used to it as well. My last visit to the stealership, the service advisor just shook his snake head & said "ssss,... don't worry about it,sssss..."
Ike Luv is offline   Reply With Quote
Old 08-12-2011, 03:16 PM   #6 (permalink)
trbod's Avatar
Date registered: Jan 2007
Vehicle: 2004 E55
Quick and skinny answer is that unlike other supercharged engines its supercharger isn't constantly engaged, there's a throttle controlled clutch to engage it. So when that clutch engages guess what happens? It makes a chirp on the belt, much like your shoe chirping on a basketball court.
Try changing the transmission from comfort to sport and notice how it engages the supercharger much faster in sport mode.
trbod is offline   Reply With Quote
Old 09-09-2011, 01:13 AM   #7 (permalink)
Date registered: Sep 2011
Vehicle: White W212, Black GTR
I think they got tired of fixing this. My buddies SL55 they actually fixed it for him by changing out the electric clutch that controls the supercharger. For my old E55 they lubed it up, but the chirp just came back after a few thousand miles. You pretty much have to get used to it...
gh429 is offline   Reply With Quote
Old 01-04-2012, 04:40 PM   #8 (permalink)
E55-SAMMY's Avatar
Date registered: Mar 2008
Vehicle: 2003 CL 55 AMG K / 2004 AUDI RS6
Its ok you can put up with it but the bearings will seize up in the end as mine did you will know when it happens as you will lose the power of the super charger all together and/or the power will stuter but you will still get the chirping noise it happend to me and the same has happend again as i got a senond hand komprossor pully instead of the pully repair kit with the new clutch ive also ordered a new bearing with the black seal on the front its a Nachi Supercharger Bearing Nachi part no. 45BG07S5AIG-2DL these are the newer bearings and last a lot longer than the old ones with the orange front cover
E55-SAMMY is offline   Reply With Quote
Old 01-06-2012, 01:48 PM   #9 (permalink)
Ike Luv's Avatar
Since I posted on this thread, I have had to replace my SC pulley/ clutch assembly. I heard the chirp one time since, which was right after the repair was done. I don't know if it was all in my mind but it seemed like the SC clutch wasn't engaging, until I did a hard WOT one time, heard the chirp then it seemed like it went back to normal. Haven't heard the chirp since.
Old 01-06-2012, 05:23 PM   #10 (permalink)
Vehicle: E55 2006 / E55 2000 / White Odyssey
How much did you pay for the SC clutch with bearing ?
E55k is offline   Reply With Quote
Bookmarks
2004 C320 "Chirping" Alarm Goes Off for No Reason WHY?!?! donniedarko New Member Introductions 1 06-05-2011 02:35 AM
"KLINK" downshifting into 1st gear? markho W123 E,CE,D,CD,TD,TE Class 5 08-31-2009 07:25 AM
New pads/Rotors - "chirping" noise radman123 W163 M-Class 3 01-31-2009 04:04 PM
New pads/rotors making "chirping" noise radman123 The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 01-28-2009 07:36 PM
"Cricket -like" chirping noise - from LH side of dash area geordie W163 M-Class 5 04-15-2003 04:26 PM
