Smell of gasoline from rear left wheel arch - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 02-15-2010, 07:55 PM Thread Starter
Date registered: Feb 2010
Unhappy Smell of gasoline from rear left wheel arch
I have a 2005 E55 and have noticed that after driving the vehicle I can detect a gasoline smell from around the area of the left rear wheel arch (drivers side - opposite the gas tank filler). There is no trace of gasoline pooling under my car after it has been sitting overnight or even for days. Anyone else experienced this type of thing? Obviously I'm concerned that there is a safety issue and plan to take it to the shop to be investigated but I thought I would post just to see if anyone else has experienced this.
Cheers
warchild is offline
post #2 of 19 (permalink) Old 02-17-2010, 08:49 PM
Date registered: Sep 2009
I had this problem on my e55. Pull the bottom of the back seat and you will find your leak. My had a crack on the pump lid.
amedina is offline
post #3 of 19 (permalink) Old 02-18-2010, 01:23 PM
Fast55's Avatar
Date registered: Oct 2004
Vehicle: 2006 E55, 2005 SLK55, a few others
There is a TSB for this. Get it to the dealer ASAP.
Fast55 is offline
post #4 of 19 (permalink) Old 02-22-2010, 05:51 PM
Date registered: Dec 2009
Vehicle: 2005 E55 AMG - sold, E320 Bluetec, Passat TDI
Cheers
Hello Warchild,
I've got the same car with a similar problem. This past weekend I pulled the rear seat cushion and accessed the gas tank from the openings thus exposed. There is a round access plate on each side of the car. Photo attached of the drivers side access hole. That is gasoline pooled at the bottom (6 o'clock position). Some E55 owners report gas leaking from the black supply hose where it connects to the nipple at the center. Mine's not leaking there. The round piece at the 3:30 position with the wires connected seems to show evidence of leakage.
I've also attached a copy of (someone else's) MB Recall Campaign Letter which addresses this issue.
Good luck. Let us know how it turns out.
/david
sgidave is offline
post #5 of 19 (permalink) Old 03-22-2010, 11:39 AM
Date registered: Mar 2010
Fuel Leaking
Thank you for posting this information! I seem to have the exact same problem, but with my 05 CLK. Unfortunately mine is not covered under this TSB. I'm on the hook for $1500.00.
bruisedlee72 is offline
post #6 of 19 (permalink) Old 03-22-2010, 12:04 PM
Hello Bruce,
Remind your service adviser that this is the SAME ISSUE addressed in the RECALL campaign notice I've attached to my post above. Remember, a recall is different from a TSB. Recalls are in effect regardless of which owner you are and the age of the vehicle. Car manufacturers don't like recalls. Depending upon your relationship with your dealer and/or Service Adviser, you might press the issue of some goodwill coverage of parts and/or labor. This is essentially a LEAKING GAS TANK and that can lead to very negative press for MB if something bad (i.e., KABOOM!!) happened. Say something to your SA like "let's be reasonable...you can fix it quietly now or I can come back later with a RECALL notice and you can fix it then" or some variation thereof. Shouldn't MB be able to built a car that's NOT prone to having fuel tank leaks?
In my case the recall work had been performed just over a year ago. I've owned my car for 4 months and it was leaking from the fuel sender. When all was said/done, my dealer picked up half the cost of the new sender which worked out to half of an $850 job.
Good luck.
/david
sgidave is offline
post #7 of 19 (permalink) Old 03-25-2010, 06:46 PM
Date registered: Jul 2009
I own a 2004 E55. I had the repair to the fuel sending unit (under warranty) completed in July of 09 and again in September of 09. The dealer replaced the gasket of the sending unit only. The fuel leak reappeared this month and I brought it in. This time my vehicle was out of warranty. Of course they replaced the sending unit, gasket and some other minor parts. I was charged $100 as a "good willl gesture". Mercedes is failing to take responsibility of a potentially hazardous defect engineered by them! Someone is going to get hurt and now there is a huge paper trail that convicts Mercedes of gross negligence. No subsequent remedial measures here. They're on notice!
GOOSELING is offline
post #8 of 19 (permalink) Old 04-07-2010, 05:39 AM
Just a follow up on my 05 CLK....
My local MB Service paid for the fuel leak fix as a 'goodwill' gesture. They saved me $1500.00 after some arguing and calls to Corporate MB, who actually called me back to open a 'case number', and contacted the Manager of my local Service Department. It does pay to argue. And especially in the case of MB NEVER, EVER accept what your service department says and question everything that they 'recommend'.
I wanted to thank you guys out there for the great information and for keeping everyone informed!
post #9 of 19 (permalink) Old 04-19-2010, 07:06 PM
Date registered: Apr 2010
E63 same issue
Glad I just read this post. I called the dealer today and asked them about gasoline smell in drivers side well and they said no knowledge of common issue. Taking it in tomorrow!
E63nNC is offline
post #10 of 19 (permalink) Old 09-01-2010, 01:17 PM
Date registered: Sep 2010
Seems there is quite a heated debate on this topic over on the MBworld forum.
Urgent notice. 03-06 E55's that were involved in the fuel sender recall are bombs. - MBWorld.org Forums
AMGtipster is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W211 E55 AMG, E63 AMG
2005 E55 Bad gas smell from left rear wheelwell atlantaman W211 E55 AMG, E63 AMG 2 11-30-2007 01:32 PM
IS there an Aftermarket item for rear wheel arch Rick Romanik R171 SLK-Class 6 11-24-2007 12:28 PM
AMG Black rear wheel arch extensions vicpaluk R171 SLK-Class 0 10-18-2007 01:50 AM
Removing clear film from rear door and wheel arch lacoula C219 CLS-Class 12 09-14-2007 08:49 AM
Tire touching Rear Wheel Arch Sabenza W210 E50 AMG, E55 AMG 2 04-14-2003 10:22 AM
