Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W211 E55 AMG, E63 AMG
Old 03-24-2008, 01:50 PM   #1 (permalink)
Date registered: Jan 2008
Electrical Draw on w211 E55
Does anybody know what the ampage draw on the battery is while the vehicle is off? I am having issues with the battery dying after about 24 hours of no use.
Thanks
Teleworker
teleworker is offline   Reply With Quote
Old 03-24-2008, 02:43 PM   #2 (permalink)
Yacht Master's Avatar
Date registered: Nov 2006
Vehicle: E-ZGO 53 HP., 99 E 430 sport, 04 E55 AMG, 2008 Tahoe LTZ Sold Porsche to Brother
Thanks
Teleworker
Time dependent, car may not be going to sleep for many reasons. The best action is to have the dealer (we all hate this part) check it out with the STAR diagnostics computer. The electrical systems have had many software upgrades in particular the charging system. Have them check both of the batteries too. These cars are so electronically intense to try and find any problem with a VOM, would be like swimming across the Atlantic.
Now that you have your suit on, disconnect the battery, say bye bye to all your pre sets, window sync, seat memory, radio, sun roof, ect... connect volt meter from battery + to battery cable, take reading wait 10 min take reading wait 10 min take reading, if it is over 100 Milliamp start pulling fuses to narrow the search. If you find a circuit that is a large consumer post your findings here.
YM
Yacht Master is online now   Reply With Quote
Old 03-25-2008, 07:19 PM   #3 (permalink)
Vehicle: 2005 E55 AMG
Battery drain
I had this issue on my 2005 E55. It kept getting the consumer features were unavailable.Came back on after I drove for awhile. Took it to the dealer (just had it for 2 days and it was CPO..phew) They initially said no drain was seen but they kept it overnight and then said...uhhhh we found something. net/net...they replaced the audio gateway.
borchelt is offline   Reply With Quote
Old 03-26-2008, 01:57 PM   #4 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Its easy to locate the draw via the SDS as several systems will take several min to shut down ...The Early W211s had issues with the Audio gateway...But as Time takes its toll on the door control units..seat control units..Comands..etc.
Make sure the dealer preforms a COMPLETE test ....and LOAD test the battery as when the battery goes dead several times it can take the battery out
Mark Cummins is offline   Reply With Quote
electrical draw parrot head W126 S,SE,SEC,SEL,SD,SDL Class 9 02-26-2004 11:48 PM
E500/W211 Electrical Problems! tboned_2002 W211 E-Class 11 11-11-2003 11:42 AM
Anyone here getting an W211 E55? Norb W211 E-Class 6 10-31-2003 04:12 PM
E55 4matic W211 maybe??????? rand W211 E-Class 0 10-17-2002 10:03 PM
E55 electrical Problems Guest (MBNZ) W210 E50 AMG, E55 AMG 8 07-09-2001 03:39 AM
