Hey guys, I have some tires which are 245/35 20 and 275/30 20 and I'm looking to buy some 20's. Does anyone know what is the offset I need so that the 20s can fit perfectly. Thanks in advance.
You have to be more specific...Its all dependant on wheel design and width. Also, you might want to specify if you are looking at cast or forged multi piece wheels....
The recommended fitment is 20x8.5 or 9.0 front with 35ET (32 is aggressive) and 20x10 or 10.5rear with low 30's ET.
The brand of tires you are running also determines if you will rub or not along with how low your suspension is set. You can do 245 or 255 front and anywhere from 275 to 295 in the rear with the right offset and spoke design.
