Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W211 E55 AMG, E63 AMG
Old 01-04-2004, 09:44 PM   #1 (permalink)
wdaley's Avatar
Date registered: Jan 2004
Vehicle: E55 AMG
keyless go programming
Does anyone know how to program the keyless go key? I have 2 keys and only 1 works as "keyless". I need to actually insert the key into the ingnition for the other key to work. Thanks.
wdaley is offline   Reply With Quote
Old 01-05-2004, 06:44 AM   #2 (permalink)
BenzWorld W211 AMG Host
Vehicle: 2004 E55-1970 280SEC
RE: keyless go programming
Two things. I heard that you must put your key in the ignition in position two for a couple of hours so that it will recognize it. Also check the number on your key, it should start with 175, if it does not its not a keyless go key.
2004 E55 Silver/Charcoal
1970 280SE/C Silver/Red
Norb is offline   Reply With Quote
Old 01-05-2004, 10:44 AM   #3 (permalink)
Arnee's Avatar
Date registered: Dec 2003
Norb - 1/5/2004 5:44 AM
Where do you check the number on the key?
This is a good segway to the question that I was going to ask anyway... Norb, do you know if I can order a non key-less go key for my [keyless-go] car?
Thanks.
Arnee is offline   Reply With Quote
Old 01-05-2004, 02:10 PM   #4 (permalink)
Its on the key near the front transponder. Very small but visible.
Yes you can order a non keylessgo key for your keylessgo car. My uncle has an E55 also and lost one of his keys. They ordered him a new one and it worked like a normal key but the keylessgo didn't work. Eventually they figured out that it was a non keylessgo key (the look identical to regular keys).
Old 01-06-2004, 10:10 AM   #5 (permalink)
Arnee's Avatar
Thanks. Mine doesn't start with 175 but it's a keyless go key. It starts with 321.
Maybe it's 175 for AMGs and 321 for non AMGs?
Old 01-07-2004, 09:11 AM   #6 (permalink)
RE: Thanks. Mine doesn't start with 175 but it's a keyless go key. It starts with 321.
Hmm, that's wierd, what are the other numbers on your key Arnee? Hee, hee. And where do you live!
Old 01-07-2004, 05:55 PM   #7 (permalink)
Arnee's Avatar
:-D
