| BenzWorld W211 AMG Host
Date registered: Aug 2002 Vehicle: 2004 E55-1970 280SEC Location: Houston, Texas USA
| Another one where Road and Track picked the E55 over RS6, M5 and Jag S-R. I especially like the first line.
1st — Mercedes-Benz E55 AMG
578.0 points
Rarely does an automobile come along that makes you run to the railing, fling your arms open and scream, "I'm king of the world!" The Audi is the most balanced overall package, but the sheer, overwhelming hot-rod thrust of this Affalterbach-built Benz can turn seen-it-all journalists into wide-eyed schoolboys. We'd like to personally thank the sole AMG technician responsible for hand-assembling this engine (his signature is on a plaque affixed to the 5.4-liter sohc V-8's Lysholm supercharger, but like a lot of signatures, we couldn't read it). The result is 469 bhp and a massive 516 lb.-ft. of torque, with the supercharger's twin screws churning at 23,000 rpm. Even right off idle, there's enough twist to easily light up the rear 265/35ZR-18 Continentals by just stepping on the gas in 1st gear. And yep, minimize the wheelspin and it's the Ferrari-beater, smoking to 60 in a mere 4.2 sec., on to an astounding 12.4-sec. quarter mile at 116.4 mph that's only a couple of tenths off the new Dodge Viper. And this in a quiet, civilized (albeit firm-riding) 4-door sedan, equally at home on a grocery run or bumping off its 155-mph speed limiter on the Autobahn.
Through our route's high-speed sweepers, the Benz felt positively glued down, delivering steering feel that's uncharacteristically communicative for a Mercedes, and very welcome. It's on the exit of tighter corners where you can feel the electronics — traction control, stability control — fighting to rein in the power. Even with stability control switched off, it still intervenes at the ragged edge, but not before allowing you to step the tail out. During strong acceleration, there's an intentional relaxation in power delivery on the upshifts to prevent the tires from spinning — perfectly timed, but noticeable. Also, through the tighter stuff on some surfaces, the front tires will chatter with extreme side load and you sense the Merc's heft.
Brakes, when used with moderate to hard pedal pressure, inspire the same huge confidence of the Audi system. And a peek between the thick spokes of the AMG-design wheels shows why, as there are immense 8-pot calipers and correspondingly large discs up front here as well. It's with light application that we find fault; Mercedes' brake-by-wire system, used in both the SL- and E-Class cars, requires delicacy of modulation for smooth around-town stops. "Not a major flaw," noted Wolfkill, "just a feature that requires a period of acclimatization."
So there are a few foibles in the running gear, but unquestionably Mercedes has crafted an interior that exudes polish, class and quality. "A very special, chic place," said Swift. Chrome-ringed, white-faced gauges are legible (though it does seem odd to have a large analog clock hog so much valuable instrument-panel real estate), and a pair of deeply supportive sports seats upholstered in Nappa/Nubuk leather offers exceptional hold, and features adjustable "clamp" of the seat bolsters. Just-so polished wood edged with chrome, and an extremely intuitive-to-use band of high-set climate controls finish the tasteful treatment.
It's nicer still for long highway stints with the S-Class-derived Airmatic suspension that quickly alters damping and spring rates as the system's accelerometers and sensors see fit, or according to four driver-selectable modes. Set in the middle of the range, the ride quality is similar to the Audi's; set full soft, it's between the Jag and BMW, all summoned from a push of what Formula 1 fan Swift dubbed the "Jenson Button" on the center console. Likewise, electronic control of the 5-speed automatic transmission sweetens the experience in either canyon-carving or cruise mode. In Mercedes' SpeedShift system, sequential changes can be made either with wheel-mounted buttons or a sideways nudge of the selector lever. Shift speed is commendably quick; and shift quality commendably smooth.
Technology, torque, luxury and true supercar performance make the E55 the new king of high-performance sedans, lacking only a version of Mercedes' 4Matic all-wheel drive to allow dialing out some of the electronic aids and dialing in a purer experience. It and the Audi have truly raised the bar for all comers in this prestigious segment. And listing at an estimated $75,000, the E55 has to be considered a relative bargain.
2004 E55 Silver/Charcoal
1970 280SE/C Silver/Red |
