My wifes car 2003 E320 W211
She was driving about a week back and check engine light came one. I checked with scanner and it coded for o2 sensors. The sensors all 4 are new about 1 year ago. I wasnt able to start troubleshooting because of work and now A few days later the SRS light came on as well. Than today while she was driving the blinkers stopped working and the temperature gauge also stopped (but rest of panel worked.). At the same time on her way home the car started flashing to "stop and stop engine because of low coolant". When she arrived home i checked the car and the coolant was fine and the car did not seem to be overheating. When she shut car off the screen stayed on and the warning of low coolant and to stop engine stayed on still AFTER the car was off??
I figured maybe something was acting goofy so i decided to disconnect the battery to hopefully reset everything. I reconnected and started back up and now the whole dashboard does not work!! Nothing!!! I checked every fuse under the hood, in trunk and on side of steering wheel. The car seems to be running fine and engine sounds fine. There is no leaks ect. Obviously this seems electrical. Anyone ever experience this?? What should i check next?
On the OBD scanner i also got a pending p0600 code.
Would the battery or aux battery be connected??
I forgot to add when i start the car now also. The front lights stay on very dim even with light switched off?? So now somehow i have daytime running lights i never had before lol
Thank you for any help
