The rear driver side door is locked and does not open until removing the door panel and release it manually. After that, I could open and close the door until I lock the car using the remote key THEN I would not be able to open the door until I remove the panel again....
Is there anything needed to be adjusted on the actuator??
P.S: I noticed two of the middle pins of the electric plug connector on the actuator are missing or broken off. I do not know whether they suppose to be that way or the insurance company broke it off when salvaging the car....
Thank you
Thank you
