How long do your rotors last in miles? Someone said the pads wear a lip which requires pad&rotors replaced at same time. Do front& rear wear at the same time?
Highway driving = 120,000 miles
City driving, soft driver (Grand Ma slowing down at a green light in case it turns red)= 80,000 miles
City driving, average driver = 60,000 miles
City driving, aggressive driver = 40,000 miles
City driving, after a bank robbery = 30,000 miles
Mixed Highway and soft driving= 100,000 miles
.................You get the picture
Anti diving feature causes the rear brakes to activate more often than normal, sometimes rear brakes wear out faster than front brakes
If the rotor minimum thickness is maintained, you can replace the pads only, the lip can be knocked off with an angle grinder, be careful not to touch the machined surface OR you can leave it alone and nothing will happen except some squealing noise for a while until the pads wear in.
When I bought W210 for wife with 170 k the rotors had bad lips on them, so I order new ones.
Fortunately amazon screw the order and after figuring out new rotors will not fit, I measured the old ones to still have 60% of usable thickness on them.
I grind the lips and now with 260k I believe we still have factory rotors on the car. We don't wear brakes much with our driving, so the rotors should be good for 1/2 milion
Akebono pads I put at 170k might last till 1/2 milion as well.
What brand of rotor should I get: Centric standard vs premium, balo, etc?
If I use ceramic pad, does it affect rotor life in city driving? (original is semi-metallic?)
After 80,000 miles on Akebono I did not notice any negative effect on rotors.
I hear some bad experience with other brands of ceramic pads, so that does not apply to everything.
Than we don't do much city driving.
I was able to wrangle a deal from a local dealer on the MB branded ones for about $8 more per rotor. They are the 330mm rotors. They were identical to the Zimmermann Z-coat rotors.
90,000 miles (140,000km) and still original rotors. Mostly city driving with some highway. The lipping has started. A mechanic told me I could just machine out the lip if needed. Anyone ever do this?
Somehow I missed that post! Thanks! Good to know! It makes sense if they are within spec still they should be fine!
