Here are two PDF files I put together containing all CDI and GASOLINE engines error codes applicable to W211 model to help members while troubleshooting their cars. It will give you idea about the problem you have but do not forget that those are complex engines and things can be very complicated and interconnected, thus you should not look at the code by itself, instead you should try to look at the whole picture of the problem.
They probably can be applied to other models of MB but I can not guarantee this.
Please do not use the Sticky thread for code discussion. Please find an existing thread about the code. If one can not be found start a new thread about the code.
Thanks
hi guys `
I hope one of you can give me a little explanation about a fault code P2333 in a 04 w211.
what does this code mean and what am I supposed to do now.
hi everyone
have a problem with my car e 320 cdi 2009 fault code that has come up is 2210-1
problem started when driving changed up the gears as normal but when slowing down wouldn't change down until you reached about 20mph, when in manual using the paddles works fine.
Thank you. I've got the infamous oil leak or a clogged EGR tube and I think this is why the MAF is getting excess oil in the system.
