how to change 2006 E350 secondary air pump and fuse - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 11-29-2012, 11:08 PM Thread Starter
Date registered: Nov 2012
Hi, I have a 2006 E350 (base) W211, recently I have a check engine light on, so I take the car to a MB dealer, and after 2hrs, they tell me the secondary airpump failed, and will cost me $1200 to get a new one, including parts and labor. Is anybody can help me out, where I can locate the secondary air pump and how to replace it or can I just fix the pump by myself. P.S. do I need change the relay too,and where is it?
thanks
MK
markde is offline
post #2 of 10 (permalink) Old 11-30-2012, 02:34 AM
Roadking999's Avatar
Date registered: Apr 2008
Vehicle: E350 4M 06
Quoted: 6 Post(s)
If you remove the front engine cover, the secondary air pump is sitting on top looking at you, its 2/3 the size of the alternater, its black with hoses and wires connected to it, it has 3 or 4 bolts.
Usually these things burn up when the relay goes bad and they stay on all the time.
If you want to go the cheapest way, you can send yours to this guy in Brooklyn and he will repair it for $95:
261135429389 (ebay item)
I havent used his services but the reports on him are good.
The relay is in the engine compartment, drivers side box. I highly recommend that you replace it as well.
When done, the CEL can be removed with SDS, it may cost you 30 minutes at ther dealer which in our case is $456,980,456,000.00
Roadking999 is offline
post #3 of 10 (permalink) Old 11-30-2012, 06:59 PM Thread Starter
Thank you so much, I will work on it this weekend. I will post the update soon
markde is offline
post #4 of 10 (permalink) Old 12-01-2012, 06:04 PM Thread Starter
I just open the driver side fuse box, open the fuse chart, but I can't found the relay box number for the secondary air pump. Anybody can tell me the relay number or the part number. Thanks ahead
MK
markde is offline
post #5 of 10 (permalink) Old 12-01-2012, 06:28 PM
Vehicle: E350 4M 06
Quoted: 6 Post(s)
N10/1kR
Name:	mercedes sap picture.jpg
post #6 of 10 (permalink) Old 12-01-2012, 11:38 PM Thread Starter
Thank you so much, work on it
markde is offline
post #7 of 10 (permalink) Old 06-04-2013, 09:19 PM Thread Starter
change the pump and relay N10/1kR ,but pump still not working, try to find the fuse, but I can't find it, can anyone tell me where is the fuse for the air pump, thanks a lot ahead:>
markde is offline
post #8 of 10 (permalink) Old 01-18-2014, 01:02 PM
Date registered: Jan 2014
Vehicle: 2006 e350
Markde did you ever solve the issue, I am now having the same problem.
Corleto is offline
post #9 of 10 (permalink) Old 09-06-2014, 02:23 AM
Date registered: Sep 2014
Originally Posted by Roadking999 View Post
N10/1kR
I have changed the secondary air pump / relay / fuse & still won't work, I'm in Australia RHD & I think I may have mistakenly identified the wrong relay. The photo as illustrated is not clear enough to positively identify the correct relay that I think I'm needing, could a member possibly furnish a more clear photo please. With thanks & cheers.
Buldog is offline
post #10 of 10 (permalink) Old 06-02-2015, 10:25 PM
Date registered: Nov 2011
Vehicle: 2001 SLK 230K
Is there contact info for the guy in Brooklyn?
czv slk 230 is offline
